cakerack
GPIO Throughput
Wed Oct 25, 2017 10:44 am
Hi All
I'm new to the Raspberry Pi community but I am looking at using the Pi to control and read a vintage disk drive. The drive in question is a CDC 9762 - an 80Mb drive first produced in the early 1970s. The interface spec is defined in ANSI standard X3.91M and reportedly runs at 9.6Mbit/s. The signals are driven differentially (+12v/-12v for logic 1) so I know I need to build some kind of translation to drive (and receive) these signals from 3.3v.
So my initial question is - what sort of throughput could I expect using the GPIO on a Pi? I currently have a Pi Zero but suspect the Pi 3 might be the one to go for? Thats if a throughput of 9.6Mbit/s is achievable... - however it doesn't have to be sustained throughput, not that that would make a difference...!
Any help or comments much appreciated!
Cheers
Sean
NotRequired
Re: GPIO Throughput
Wed Oct 25, 2017 11:53 am
It depends a lot of the implementation, but compiled C or assembly may get about 25Mhz bursts on a Pi3: viewtopic.php?t=26907 so 9.6Mbit should be possible :)
Please do not ask questions in private messages, they will not help others.
cakerack
Re: GPIO Throughput
Wed Oct 25, 2017 12:31 pm
Ok thanks for the reply - I plan on doing some testing soon so I will report back!
Cheers
Sean
piras77
Re: GPIO Throughput
Wed Oct 25, 2017 7:00 pm
You may want to have a look at this thread: viewtopic.php?f=44&t=191949
