My name is David.
This is my 1st post here.
I apologize for my English, hope you can understand me.
I have been using Raspberry PI 2 & 3 as VPN server, OSMC Media Center, Recalbox device, etc. in short words....ready made systems.
Now I have a challenge.
I have a device which is a PID controller.
It read via its own 2 analog input (4~20mA) 2 values from 2 pressure transducers
Then it control an inverter giving out (analog output (4~20mA))
The manufacture closed down and there is no alternative on the market.
Inside this box there is an algorithm which, based on the result of the 2 INPUT, it gives out 1 OUTPUT (based on 2 pressures, it control 1 frequency inverter (electrical motor).
The range of pressure is 0 to 1013 mbar.
The 2 input I will call them INP1 and INP2
The range of frequency inverter that control the motor is 0~50hz
The 1 output I will call it OUT1
What they recommend me is to connected these analog ports to a PLC or a DEVICE with ANALOG INPUT/OUTPUT and read what is the OUT2 for each combination of INP1 with INP2.
By the way INP1 cannot be > than INP2
Example:
with INP1 = 1013
with INP2 = 1013
then OUT1 = ???
with INP1 = 1012
with INP2 = 1013
then OUT1 = ???
with INP1 = 0
with INP2 = 1013
then OUT1 = ????
with INP1 = 1012 (remember that INP1 is always < or = of INP2)
with INP2 = 1012
then OUT1 = ???
and have these results in a writable file.
From there I would like to create a formula (algorithm) and make my own device using RASPBERRY or ARDUINIO.
My questions are :
(1) Do you think is possible using RASPBERRY PI ?
(2) If yes, any link to any special version (unipi.technology or similar product) with already Analog INPUT/OUTPUT ?
(3) What software / coding you would recommend to read (and make a file) with the results ?
Thanks in advance
David
