Most narrow keyboard available of any kind? My ideas so far.
Posted: Sat Oct 07, 2017 2:37 pm
I have been searching for keyboards to use in a pocket device.
https://www.amazon.com/HP-355916-001-Th ... b+keyboard
This is a Pocket PC clip on keyboard that may use USB internally but would needs to be partially disassembled for sure. See the pinout here:
http://pinouts.ru/PortableDevices/ipaq_12p_pinout.shtml
This shows USB data connections but I'm not sure if the keyboard internally uses the USB HID protocol or not.
https://www.amazon.com/TYPO-Keyboard-iP ... o+keyboard
This may work but is expensive, rare and may be somehow Iphone-only.
http://ipazzport.com/en_productinfo.asp?id=157
This is bluetooth and battery powered but is almost perfect otherwise. I could setup bluetooth keyboard auto-connect and wire the battery leads to my main battery as a solution. Unfortunately it seems sold out right now and I could only see a few questionable retailers to buy it from. If nothing else I might get a prepaid card and buy one of these from a few different places in the hopes that I actually receive one some day.
Things like this look like they would fit the bill but they don't:
https://www.amazon.com/Bluetooth-Keyboa ... h+keyboard
This is actually a huge 4.5" wide clunky keyboard. The ones above are all in the 3 inch range and smaller.
By the way, the reason it seems like many of these don't exist is Blackberry. They strongarmed the Typo keyboard manufacturers into never making another keyboard. Even though they were far from the first people to envision a mobile device with a keyboard on the front. See the Dynabook:
https://en.wikipedia.org/wiki/Dynabook
Thanks for any input you can give, so to speak.
