satimis
About booting USB mass storage
Tue Sep 12, 2017 1:52 pm
Hi all,
I'm prepared to test booting on USB mass storage. My concept is on powering up Raspberry Pi it would boot directly the USB mass storage similar to Live CD without the assistance of the microSD card.
However in going through following document:
How to boot from a USB Mass Storage Device on a Raspberry Pi 3
https://www.raspberrypi.org/documentati ... des/msd.md
It still needs the file /boot/config.txt on microSD card working as bios to start booting.
If I'm wrong please advise me.
Regards
satimis
Jednorozec
Re: About booting USB mass storage
Tue Sep 12, 2017 2:11 pm
You only need the SD card to set the USB boot mode after which you no longer need it.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
satimis
Tue Sep 12, 2017 2:35 pm
On next boot do I still need the microSD card? Can I remove it?
satimis
DirkS
Tue Sep 12, 2017 4:34 pm
satimis
You're actually quoting the answer to your question.
It's actually 'worse': if you don't remove the SD card the Pi will boot from that; not from the USB device.
hommar
Tue Sep 12, 2017 7:52 pm
SD need for first boot only
This boot need for turn on "USB boot"
Yesterday, I make USB recovery (as Live-CD on PC)
I use my old 16gb USB mass storage
1) I make "boot" partition 12Gb, because this partition I can use on Windows
2) I copy original last Raspbery Lite root to second partition (full image is 14Gb)
3) I uninstall default swap - dphys-swapfile
4) I make several optimizations (zswap + tmpfs for tmp-folder, logs and caches)
5) I change local for Russia users ;) (wifi-country too), but keyboard change to EN, it's better for recovery tools... (keyboard "GB" is not good idea)
6) I make wpa_supplicant.conf for easy edit
You can test it
PS For example, now I can backup SD to first partition, and read this on Windows systems
satimis
Wed Sep 13, 2017 9:28 am
- snip -
Your advice noted.
Where the edited /boot/config.txt is saved? On the USB device?
Regards
satimis
satimis
Wed Sep 13, 2017 9:38 am
- snip -
You can test it
Your advice noted and thanks.
Re: "3) I uninstall default swap - dphys-swapfile"
Where this file resides? On the microSD card or the mass SD storage?
Re: "4) I make several optimizations (zswap + tmpfs for tmp-folder, logs and caches)" and "6) I make wpa_supplicant.conf for easy edit"
Where are those files located.
The link is in Russian. Sorry I can't read it>
Regards
satimis
hommar
Wed Sep 13, 2017 10:18 am
apt-get purge dphys-swapfile
or
sudo dphys-swapfile swapoff
sudo dphys-swapfile uninstall
sudo update-rc.d dphys-swapfile remove
you can read this
(I think you can understand it, because codes is in English. PS _AI_ is me)
But zram I run in /etc/rc.local now, because it easy
/etc/wpa_supplicant/wpa_supplicant.conf
right top is buttons [Move on your yandex disk][Download] (left button is yellow, but you need right)
First run you can change local to English - run command raspi-config.
PS I install mc, disable bluetooth on /boot/config.txt and change time zone to Yelaterinburg ;) You can change last on raspi-config too.
Regards, Anatoly
i486
Wed Sep 13, 2017 12:13 pm
Where is remembered the new boot mode? RPi does not have battery RAM or system flash (AFAIK).
Wed Sep 13, 2017 12:17 pm
There are a set of One Time Programmable bits in the Pi. They contain things like the serial number, model number and a few settings. One of those bits are where the boot option is stored. Being OTP it can be turned on, but never turned off again.
i486
Wed Sep 13, 2017 12:40 pm
This means that serial number can be changed (setting other bits)?
asavah
Wed Sep 13, 2017 2:09 pm
No.
It's OTP - One Time Programmable, once programmed those bits can't be changed and serial, model and some other bits were already burned at factory.
RaTTuS
Wed Sep 13, 2017 2:19 pm
no
Covfefe
Wed Sep 13, 2017 2:49 pm
In theory any bit that isn't set can be set, but they can't be written from Linux, it would have to be done by the boot code which is not ARM code and is closed source.
One example was when some Pis were sent out without the model number set (all zeroes) and there was a "secret" command to put in config.txt that could be used to set it to the correct value.
The USB boot flag is one of the few that are user settable.
