satimis
How to make blue tooth speaker to work?
Sat Sep 09, 2017 2:36 pm
Hi all,
Raspberry Pi3 model B
I followed;
PLAY AUDIO ON A BLUETOOTH SPEAKER WITH RASPBERRY PI 3
https://www.raspberrypi.org/magpi/bluet ... erry-pi-3/
trying to make the blue tooth speaker to work without success.
following software have been installed:-
pi-bluetooth
blueman
pulseaudio
pavucontrol
pulseaudio-module-bluetooth
Reboot did not help. The built-in speaker on display works. There is no error message on PulseAudio Volume Control.
Please help. Thanks
RaspberryPi is connected to wifi router. Would this setup affect?
Edit:
On further tuning, blue tooth is connected. The speak broadcasts ¨Connect to blue tooth¨. But no music of youtube broadcasts on the speaker.
Regards
satimis
Douglas6
Re: How to make blue tooth speaker to work?
Sat Sep 09, 2017 7:17 pm
If you are running the Stretch version of Raspbian, PulseAudio is not needed. I'm not sure if it interferes, but you might want to uninstall it. Blueman is never a good idea, I'd uninstall that as well. I don't believe Bluetooth audio will work if audio is routed to HDMI, sounds like you'll want to change that to the onboard audio system, with raspi-config.
OutoftheBOTS
Sat Sep 09, 2017 8:23 pm
it is very easy.
Left click on the Bluetooth icon at top right of screen then follow normal pairing procedure of Bluetooth device. After it has paired then right click on the volume icon next to it and select Bluetooth speaker :)
satimis
Sun Sep 10, 2017 12:59 pm
it is very easy.
I found the device, the speaker, there but unable to connect it.
Select connect:
Warning
Connection failed - Use the Audio Menu to connect to this device
Where is the Audio Menu?
Regards
satimis
satimis
Sun Sep 10, 2017 1:28 pm
Uninstall all packages, previously installed, running:
$ sudo apt --purge remove pi-bluetooth blueman pulseaudio pavucontrol pulseaudio-module-bluetooth
Reboot RaspberryPi
On right top -> left-click ¨Manage Bluetooth Devices¨
No Bluetooth Adapter found
Regards
satimis
Douglas6
Sun Sep 10, 2017 2:06 pm
You need pi-bluetooth. It comes installed on recent versions. Try reinstalling.
DirkS
Sun Sep 10, 2017 2:08 pm
re-install pi-bluetooth
It loads the firmware to the BT module of thte Pi3B
satimis
Sun Sep 10, 2017 4:01 pm
Hi all,
Reinstall pi-bluetooth but problem remains.
Left-click ¨Manage Bluetooth Device
select the device ¨Awei-y200¨
-> connect..
On terminal:-
$ bluetoothctl
[NEW] Controller B8:27:EB:75:C8:3C raspberrypi [default]
[NEW] Device 30:21:5B:6C:54:FD Awei-Y200
[bluetooth]# connect 30:21:5B:6C:54:FD
Attempting to connect to 30:21:5B:6C:54:FD
[CHG] Device 30:21:5B:6C:54:FD Connected: yes
Connection successful
[CHG] Device 30:21:5B:6C:54:FD ServicesResolved: y
But still fail. No music plays on the speaker
Music plays on the display built-in speakers
Regards
satimis
Douglas6
Sun Sep 10, 2017 4:18 pm
satimis
Sun Sep 10, 2017 4:23 pm
Hi all,
Tried again.
Connected Raspberry Pi to another display, Dell 25" display without built-in speakers.
Left-click ¨Manager Bluetooth devices¨
-> Connect ...
This time it connected the bluetooth speaker. But still no music played. The Volume control was turned to max.
satimis
OutoftheBOTS
Sun Sep 10, 2017 7:56 pm
speaker :)
Select connect:
Warning
Regards
satimis
Perfect that means the Bluetooth speaker is paired now you just have to select that you want to use the bluetooth speaker as your audio so right click on the volume icon at the top right and select the bluetooth speaker as your audio device.
Don't go uninstalling anything. The Raspbian OS is setup perfect straight out of the box if your using Jessy or Stretch
satimis
Wed Sep 13, 2017 3:09 pm
speaker :)
Select connect:
Warning
Regards
satimis
Hi all,
Having tried 2 days still unable to make the bluetooth speaker to work.
Bluetooth manager found the device, the speaker. Also I have on the volume icon selected the bluetooth device. The built-in speakers of the display continue to play without problem.
Then I connected the speaker direct to the phone output of Raspberry Pi with a cable. Still there was no sound.
It is very strange to me. The bluetooth speaker is working without problem. I have tested it on my Samsung mobile phone, both bluetooth connection and direct connection with cable.
Regards
satimis
OutoftheBOTS
Thu Sep 14, 2017 1:22 am
Strange.
I am still using Jessie OS and haven't yet updated to Stretch. I have many RPi devices and have connected many of then to blue tooth speakers as easily way fro me to get sound out of the RPi.
I don't know if it is a stretch problem or a problem with the earlier posts where you deleted some drivers but it works for me straight out of the box
satimis
Thu Sep 14, 2017 1:38 am
Strange.
I have reinstalled all of them. The AWEI Y200 bluetooth speaker detects bluetooth, saying bluetooth connected (there is a pre-recorded message on it), but no sound plays. The strange thing is even I connect the speaker with cable still no sound played.
On my desktop PC, running Ubuntu 16.04, there is a sound setting tab for selecting HDMI, Digital Output, Analog Output etc. Is there a similar settings on Raspberry Pi3 B? My Samsung 24" display with built-in speakers is with HDMI connection. I suppose the sound output is the same.
satimis
Douglas6
Thu Sep 14, 2017 1:47 am
satimis
Thu Sep 14, 2017 2:57 am
[I don't believe Bluetooth audio will work if audio is routed to HDMI, sounds like you'll want to change that to the onboard audio system, with raspi-config.
Just started Raspberry pi3 B
-> Preferences -> Raspberry Pi Configeration
No items related found.
-> Preferences -> Audio Device Settings
Sound card: bcm2835 ALSA (Alsa mixer)(Default)
no other items available there for selection
Playback
PCM set to max (no other items there)
Select Controls .. (Only PCM there)
Edit
On terminal run;
$ sudo raspi-config
Also no items related found there
$ sudo nano /boot/config.txt
uncomment hdmi_drive=2
reboot Raspberry
Still the same without sound output except on the built-in speakers of the display.
satimis
satimis
Thu Sep 14, 2017 2:16 pm
Hi all,
Now I can make the bluetooth speaker to work via cable (the phone jet)
Right-click the loudspeaker icon on the right corner of the panel -> select Analog
But still I can't make it work via bluetooth.
satimis
OutoftheBOTS
Thu Sep 14, 2017 8:45 pm
This may need someone Raspberry pi foundation to look at.
Considering the speaker is working vai analog and it is paired but when you switch from analog to blue it doesn't work.
1 other thing that I would try, if you have a spare SD card then try botting up with Jessy and see if it will work there just so that you eliminate the stretch OS
satimis
Fri Sep 15, 2017 2:26 am
Whether you suggest download Raspbian “jessie” on following website?
https://www.raspberrypi.com.tw/10366/di ... ssie-lite/
and install it on another microSD card?
This is the second Raspbian image 2017-09-07-raspbian-stretch.zip (on a new microSD card)
Previously I was testing the Raspbian image 2017-08-16-raspbian-stretch.zig (on another microSD card)
I don't have no more spare microSD card. However I have a spare full size 64G SD card.
I'll try more on this new Raspberry image first before I install “jessie” on the full size SD card.
Regards
satimis
QMESAR
Fri Sep 15, 2017 4:26 am
Hi All.
It seems that Raspberry PI Bluetooth are very unstable,
Initially I also had much trouble in getting Blue tooth speakers working over BT after the latest update it is possible to connect to the BT speakers ,it is somehow trivial one time it will play sound and 9 time no sound even with the pairng successful,then most of the time when you do have sound it constantly drops the sound then you have to remove the BL device in the RPI BT connected devices and do a complete search ,find connect and pair of the BT device and then again if you lucky you have sound if you have sound it could drop again .
I have to say also that the speakers are working 100% stable with my Android phone over BT so the issue is in the RPI/BT HW or SW for me not with the speakers
Kind Regards
QMESAR
jardino
Fri Sep 15, 2017 11:18 am
I am experiencing similar problems, using two known good bluetooth audio devices and both jessie and stretch.
Alan.
IT Background: Honeywell H2000 ... CA Naked Mini ... Sinclair QL ... WinTel ... Linux ... Raspberry Pi.
Vicky P
Sun Oct 15, 2017 1:17 pm
I am also having this problem and the networking, in terms of connecting to other computers on a home network from the Pi, is also not working properly. I have to submit a password, which IS NOT remembered, in order to connect to other computers on my network. It cannot be my hardware because everything works fine in the last Jessie image. I am not trying to do this via HDMI. I have tried all these suggestions, except for re-installing the pi-bluetooth driver. Everything connects to the speaker properly, supposedly, and it delivers no sound.
VinPiUser
Mon Oct 16, 2017 8:15 pm
I'm having the same issue. My earlier post: viewtopic.php?f=91&t=195470
I have a couple of Blue tooth speakers that work fine with my Android device.
The Bose Soundlink pairs and connects, but there's no sound. My Sony speaker will not pair.
My Pi 3 is running the 'Jessie' version.
My next step is download and switch over to the latest Stretch release and see if the bluetooth issues are resolved.
If I get Bluetooth working on Stretch with my two speakers, I'll update my post.
- V.
rainer.brito
Tue Oct 17, 2017 2:22 pm
I suggest you report and confirm this issue on GitHub: https://github.com/raspberrypi/firmware/issues
Also, check this thread: viewtopic.php?f=66&t=191073&start=25
We are all experiencing this kind of issue with BT speakers.
There is no permanent fix yet.
aceinthedeck
Tue Oct 17, 2017 9:14 pm
I am having the same problem. I have been trying to connect the bluetooth speaker for 2-3 days now. Here what I have tried.
Connected the speaker successfully using command line (and GUI as well).
Routed the audio to bluetooth speaker via audio menu.
The speaker works perfectly on other devices.
The sound from 3.5 mm works on Raspberry Pi only bluetooth doesnt work.
I think it is a problem with the Operating system.
