aekanshgupta96
Establishing connection with PLC.
Mon Sep 04, 2017 7:31 am
HI, I am working on a project where i have to collect data about temperature and humidity from plc which will be accessed by raspberry pi and then the pi will upload it on to the cloud. I mean how do i establish a connection between plc and pi and even if i somehow manage to do so what should i write in the program for the pi to access the data.I have no clue.
fladda
Re: Establishing connection with PLC.
Mon Sep 04, 2017 10:44 am
Recommend using Python as the programming language, Modbus RTU (serial) and RS-485.
bask185
Mon Sep 04, 2017 2:02 pm
Use Rs232, you can buy a USB-rs232 cable, with it you can hook up your pi directly on the PLC (assuming PLC has a RS232 port). I don't know much about python other than that it is not the fastest software
I had a Pi working as a MMI with Qt software. It worked extremely well and it was fast.
You can also wright a program in C using any text editor. This is propably the most efficient way.
