Tichun
Onboard WiFi unstable again
Fri Sep 01, 2017 8:54 am
No wlan interface found or it stops working during usage.
As always it happens out of sudden and there are some /var/log/kern.log messages:
brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a7837
Aug 31 12:35:09 pi kernel: [ 6699.332819] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:09 pi kernel: [ 6699.332833] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:15 pi kernel: [ 6705.107156] net_ratelimit: 3 callbacks suppressed
Aug 31 12:35:15 pi kernel: [ 6705.107172] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:15 pi kernel: [ 6705.107180] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:20 pi kernel: [ 6710.227133] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:20 pi kernel: [ 6710.227148] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:25 pi kernel: [ 6715.347232] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:25 pi kernel: [ 6715.347246] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:28 pi kernel: [ 6717.907271] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:28 pi kernel: [ 6717.907283] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:37:36 pi kernel: [ 6846.065440] brcmfmac: brcmf_link_down: WLC_DISASSOC failed (-110)
Aug 31 12:37:39 pi kernel: [ 6848.705426] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 12:37:39 pi kernel: [ 6848.705439] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 12:37:41 pi kernel: [ 6851.265526] brcmfmac: _brcmf_set_multicast_list: Setting mcast_list failed, -110
Aug 31 12:37:44 pi kernel: [ 6853.825506] brcmfmac: _brcmf_set_multicast_list: Setting allmulti failed, -110
Aug 31 12:37:46 pi kernel: [ 6856.385515] brcmfmac: _brcmf_set_multicast_list: Setting BRCMF_C_SET_PROMISC failed, -110
Aug 31 12:37:51 pi kernel: [ 6861.505692] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:37:54 pi kernel: [ 6864.065609] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:37:54 pi kernel: [ 6864.065624] brcmfmac: brcmf_cfg80211_reg_notifier: Country code iovar returned err = -110
Aug 31 12:37:57 pi kernel: [ 6866.625675] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 12:37:57 pi kernel: [ 6866.625688] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 12:45:40 pi kernel: [ 7330.308022] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:45:40 pi kernel: [ 7330.308037] brcmfmac: brcmf_cfg80211_get_tx_power: error (-110)
Aug 31 12:45:43 pi kernel: [ 7332.868138] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 14:03:55 pi kernel: [ 1190.709074] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:04:02 pi kernel: [ 1198.099118] net_ratelimit: 2 callbacks suppressed
Aug 31 14:04:02 pi kernel: [ 1198.099134] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 14:04:02 pi kernel: [ 1198.099142] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:19:35 pi kernel: [ 2131.226260] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 14:19:35 pi kernel: [ 2131.226274] brcmfmac: brcmf_cfg80211_add_key: get wsec error (-110)
Aug 31 14:19:38 pi kernel: [ 2133.786275] brcmfmac: brcmf_cfg80211_disconnect: error (-110)
Aug 31 14:19:41 pi kernel: [ 2137.066292] brcmfmac: brcmf_run_escan: error (-110)
Aug 31 14:19:41 pi kernel: [ 2137.066309] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 14:56:16 pi kernel: [ 4332.521464] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 14:56:16 pi kernel: [ 4332.521538] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:56:16 pi kernel: [ 4332.525699] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.529582] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.533793] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.538108] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.541649] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.545838] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.549842] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.725655] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 14:56:32 pi kernel: [ 4347.914643] net_ratelimit: 8 callbacks suppressed
Aug 31 15:36:35 pi kernel: [ 6751.085648] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 15:36:35 pi kernel: [ 6751.085717] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 15:36:35 pi kernel: [ 6751.089886] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.094013] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.097840] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.101993] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.105962] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.110106] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.114222] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.114283] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Sep  1 02:22:17 pi kernel: [  126.104658] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x09800, err: -84
Sep  1 02:22:27 pi kernel: [  135.772685] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x09800, err: -110
Sep  1 02:24:52 pi kernel: [  280.854368] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x09800, err: -110
Sep  1 02:24:52 pi kernel: [  280.858570] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x09800, err: -84
I removed repeating lines, for some went on for multiple seconds or nearly an hour, and so this post would take lots of pages to scroll through with the same messages over and over.
Re: Onboard WiFi unstable again
Fri Sep 01, 2017 9:13 am
Thanks for the report. I'm a bit stuck on another project at the moment - will get back to Wifi asap.
gregoryo
Tue Sep 19, 2017 4:52 pm
just registered here on forum. I was googling on same problem and found this thread. So I'm having same issue.
Today I found the PI in state that I cant connect via wifi, logs show below:
Sep 19 06:23:12 raspberrypi kernel: [33501.969655] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Sep 19 06:23:12 raspberrypi kernel: [33501.969737] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Sep 19 06:23:12 raspberrypi kernel: [33501.973903] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
Sep 19 06:23:12 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Tue Sep 19 06:24:42 2017 [try http://www.rsyslog.com/e/2007 ]
Sep 19 06:23:12 raspberrypi kernel: [33501.978175] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.982357] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.986389] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.990583] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.994881] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.999382] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Sep 19 06:23:12 raspberrypi kernel: [33501.999468] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Sep 19 06:23:47 raspberrypi kernel: [33537.182269] net_ratelimit: 18 callbacks suppressed
Sep 19 06:23:47 raspberrypi kernel: [33537.182277] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sl
After finding nothing today I run rpi-update anyway. So now i'm running latest stuff and 4.9.50-v7+ #1035 .
We will see during the night if that helped.
BR,
Gregory
EDIT. Same, wifi hangs after approx 1h from boot.
wh7qq
Wed Sep 20, 2017 9:04 pm
WiFi is never going to have the security and stability of an ethernet connection. The 3B wireless connectivity was so poor on mine that I had to install an outboard, full sized antenna which of course, voided any warranty the second I put the soldering iron to the board. I can't speak for the Zero W as I have heard that it was improved over the 3B but those tiny chip antennas will never have the functionality of a full size antenna...size and signal capture area really do matter and wireless gets no special breaks from the laws of physics.
That said, you have not identified the model Pi you are using or your distance, floors, walls, file cabinets, etc, between your Pi and the router or AP. If your signal strength is on the edge when it is working, atmospheric conditions can cause it to disconnect.
You might have better luck with a USB wireless dongle, especially one of the models with a movable full size antenna such as the Panda PAU06.
HermannSW
Wed Sep 20, 2017 9:16 pm
I have tested Pi Zero W wireless connectivity with built in antenna inhouse with direct line of sight, and got good connection quality (30/70) over 55m as well as over 170m(!):
viewtopic.php?f=43&t=190407&p=1201953#p1204793
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/working_with_FPGAs
davidcoton
Wed Sep 20, 2017 10:23 pm
It also voids the wIfi type approval, which in many places makes it illegal to operate. :shock:
If you do need an external antenna, connect it through a dongle designed for an external antenna. Avoid upsetting the boys in blue or men in black suits. 8-)
