As always it happens out of sudden and there are some /var/log/kern.log messages:
brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a7837
Aug 31 12:35:09 pi kernel: [ 6699.332819] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:09 pi kernel: [ 6699.332833] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:15 pi kernel: [ 6705.107156] net_ratelimit: 3 callbacks suppressed
Aug 31 12:35:15 pi kernel: [ 6705.107172] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:15 pi kernel: [ 6705.107180] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:20 pi kernel: [ 6710.227133] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:20 pi kernel: [ 6710.227148] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:25 pi kernel: [ 6715.347232] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:25 pi kernel: [ 6715.347246] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:35:28 pi kernel: [ 6717.907271] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 12:35:28 pi kernel: [ 6717.907283] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 12:37:36 pi kernel: [ 6846.065440] brcmfmac: brcmf_link_down: WLC_DISASSOC failed (-110)
Aug 31 12:37:39 pi kernel: [ 6848.705426] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 12:37:39 pi kernel: [ 6848.705439] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 12:37:41 pi kernel: [ 6851.265526] brcmfmac: _brcmf_set_multicast_list: Setting mcast_list failed, -110
Aug 31 12:37:44 pi kernel: [ 6853.825506] brcmfmac: _brcmf_set_multicast_list: Setting allmulti failed, -110
Aug 31 12:37:46 pi kernel: [ 6856.385515] brcmfmac: _brcmf_set_multicast_list: Setting BRCMF_C_SET_PROMISC failed, -110
Aug 31 12:37:51 pi kernel: [ 6861.505692] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:37:54 pi kernel: [ 6864.065609] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:37:54 pi kernel: [ 6864.065624] brcmfmac: brcmf_cfg80211_reg_notifier: Country code iovar returned err = -110
Aug 31 12:37:57 pi kernel: [ 6866.625675] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 12:37:57 pi kernel: [ 6866.625688] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 12:45:40 pi kernel: [ 7330.308022] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 12:45:40 pi kernel: [ 7330.308037] brcmfmac: brcmf_cfg80211_get_tx_power: error (-110)
Aug 31 12:45:43 pi kernel: [ 7332.868138] brcmfmac: brcmf_do_escan: error (-110)
Aug 31 14:03:55 pi kernel: [ 1190.709074] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:04:02 pi kernel: [ 1198.099118] net_ratelimit: 2 callbacks suppressed
Aug 31 14:04:02 pi kernel: [ 1198.099134] brcmfmac: brcmf_sdiod_sglist_rw: CMD53 sg block write failed -84
Aug 31 14:04:02 pi kernel: [ 1198.099142] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:19:35 pi kernel: [ 2131.226260] brcmfmac: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
Aug 31 14:19:35 pi kernel: [ 2131.226274] brcmfmac: brcmf_cfg80211_add_key: get wsec error (-110)
Aug 31 14:19:38 pi kernel: [ 2133.786275] brcmfmac: brcmf_cfg80211_disconnect: error (-110)
Aug 31 14:19:41 pi kernel: [ 2137.066292] brcmfmac: brcmf_run_escan: error (-110)
Aug 31 14:19:41 pi kernel: [ 2137.066309] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Aug 31 14:56:16 pi kernel: [ 4332.521464] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 14:56:16 pi kernel: [ 4332.521538] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 14:56:16 pi kernel: [ 4332.525699] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.529582] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.533793] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:16 pi kernel: [ 4332.538108] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.541649] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.545838] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.549842] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 14:56:17 pi kernel: [ 4332.725655] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 14:56:32 pi kernel: [ 4347.914643] net_ratelimit: 8 callbacks suppressed
Aug 31 15:36:35 pi kernel: [ 6751.085648] brcmfmac: brcmf_sdio_bus_sleep: error while changing bus sleep state -110
Aug 31 15:36:35 pi kernel: [ 6751.085717] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Aug 31 15:36:35 pi kernel: [ 6751.089886] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x1000d, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.094013] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.097840] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.101993] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.105962] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.110106] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x1001a, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.114222] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x10019, err: -110
Aug 31 15:36:35 pi kernel: [ 6751.114283] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
Sep 1 02:22:17 pi kernel: [ 126.104658] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x09800, err: -84
Sep 1 02:22:27 pi kernel: [ 135.772685] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x09800, err: -110
Sep 1 02:24:52 pi kernel: [ 280.854368] brcmfmac: brcmf_sdiod_regrw_helper: failed to read data F1@0x09800, err: -110
Sep 1 02:24:52 pi kernel: [ 280.858570] brcmfmac: brcmf_sdiod_regrw_helper: failed to write data F1@0x09800, err: -84
