StefanGriffiths
Cycling Sensors for Cycling Computer
Sun Aug 06, 2017 12:18 pm
For my 3rd year Dissertation I'm making a cycling computer using a "Raspberry Pi" and I had a question.
What type of motion sensors would I need to have to go on the wheels of my bike that register with a raspberry pi, I need to be able to record the speed at which I'm travelling.
Any suggestions would be great.
Many Thanks
bitbank
Re: Cycling Sensors for Cycling Computer
Sun Aug 06, 2017 5:36 pm
Something like this would work:
http://www.ebay.com/itm/IR-Optical-Limi ... 2749.l2649
You can look at my pi_car project for the code to talk to it. You set up a GPIO interrupt and count the pulses in the callback routine.
https://github.com/bitbank2/pi_car
The fastest code is none at all :)
Sun Aug 06, 2017 6:39 pm
Use a hall-effect sensor with a magnet on a spoke.
You can then use wheel size and 3.141592 (π) to determine how far you've moved in one revolution. https://www.sheldonbrown.com/cyclecompu ... ation.html gives 2097mm for my 700*23c road wheels.
aTao
Sun Aug 06, 2017 7:39 pm
No, you cant! The outer edge of a bicycle tyre is not a circle, and you will not measure its diameter that accurately.
Any way, when I were a lad we used to clothes peg a card to the frame so every spoke hit it... Calibrate pitch of thrrrrap to a measured distance
But seriously, as Dougie says, hall effect is most reliable, but do calibrate it over a known distance since wheel measurements can be misleading.
drgeoff
Sun Aug 06, 2017 7:51 pm
Many of the cheap cycle computers use a magnet and a reed switch. In a quiet room with the bike upside-down, move the wheel backwards and forwards with the magnet near the sensor and you can hear the reed switch click as it makes and breaks.
Sun Aug 06, 2017 8:06 pm
You know that, I know that. But it's a pain to mark a straight line, mark a point on the tyre where it touches the road, move the bike along the line until the point on the tyre touches again. Then measure distance (when the website I found has done all that stuff and produced average values for average wheel sizes).
bensimmo
Sun Aug 06, 2017 9:22 pm
All sorts of methods.
Traditionally a roller on the tyre turning a wire cable, then a reed switch and magnet.
Now Hall effects, lasers, GPS, whatever you can imagine and try.
Reed switch is dead easy, it's just a 'switch' on/off and has worked for many many years for front, rear and cranks speed/cadence measurements.
Either use tables to get the tyre diameter, most 'speedos' BiTD came with tables of values e.g. https://www.cateye.com/files/manual_dl/ ... 0_v7_E.pdf or good old* Sheldons site (or mark and ride on a few turns and average it out) That methods been around since I was small and probably before that, and that's BBC Micro era.
Forgive me but what age is "3rd year Dissertation" as it doesn't sound a lot for a Final year Degree course (which is what I know as that)
*well dead :-(
danjperron
Sun Aug 06, 2017 9:34 pm
I did a small python code with a small sensor on this post!
viewtopic.php?p=812499#p812499
It is quite simple anyway!
aTao
Sun Aug 06, 2017 11:24 pm
was think more "measured mile" than one rotation.... As well as average wheel sizes, it also includes... err... cyclist's girth.
StefanGriffiths
Mon Oct 02, 2017 4:13 pm
What Model would be best for a cycling computer, because from what ive looked at the Raspberry Pi Model 3 satisfies what I need for the cycling computer?
PiGraham
Mon Oct 02, 2017 4:32 pm
Model 3 is OK. Pi Zero uses less power which gives longer life on batteries. Any model Pi will have limited life on battery compared to a typical bicycle computer.
scotty101
Mon Oct 02, 2017 4:48 pm
At Uni we made a cycle computer for our second year Real Time Operating System course using a Freescale 68HC12 microcontroller* which is significantly less powerful than any of the raspberry pi's. Any model of Pi would be capable of this.
As PiGraham has mentioned, if battery life is a concern for you project, you might be better off using a Pi Zero or a much simpler microcontroller, perhaps an arduino.
*Even the 68HC12 was overkill for this application.
bensimmo
Mon Oct 02, 2017 8:34 pm
Any, cheapest possible really.
But it depends how far you wish to take it I guess.
Want WiFi or Bluetooth then you need the Pi3 or ZeroW for ease of use.
Personally I would go Zero/ZeroW.
Of course you can then add GPS to log routes.
Accelerometers to see what you can get from that.
Pedaling cadence (similar to wheel velocity).Strain gauges, suspension travel measurements, Bluetooth air valve pressure. Temperature and barometers, pressure...
Possibly ANT connected devices (no idea on this, but that's Bluetooth).
Remote readings, light charge checking etc...
Fun light control, auto turn on, dim and even indicators etc.
Oh and possibly a display.
przemof
Mon Sep 24, 2018 10:04 pm
I use pi zero w + BLE speed and cadence sensors and a few more for heart rate, pressure/altitude, temperature, GPS & more. Keeping all exceptions from bluepy under control was a major challenge. Code is here: https://github.com/PrzemoF/Open-Cycling-Computer
Imperf3kt
Mon Sep 24, 2018 10:20 pm
I do not suggest a Pi3b or Pi3b+, you'll have a lot of difficulty powering it reliably.
The Pi0w looks like a great option, to me. Might try this myself, my bike has sat in the garage ever since I bought it. (It does have a computer on it which somehow still runs on the same batteries it came with several years ago), but all it does is tell me my speed, average speed, top speed, km travelled and the time.
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
LTolledo
Mon Sep 24, 2018 10:30 pm
For a DIY project looks interesting and challenging... and fun time doing it.
however an off-the-shelf cycling computer with Bluetooth and/or ANT+ would probably be cheaper and less troublesome than the RPiZW version.
have several for my road bikes (road-racer bikes).
but then again nobody is stopping anyone from doing the challenge..... ;)
Some people be like:
przemof
Mon Sep 24, 2018 10:44 pm
Considering how much time and money I've spent doing it... I could probably buy a large box of top line garmins :D
Anyway, I'll take over the market of cycling computers when the project is finished ;)
energyi
Wed Sep 26, 2018 10:33 pm
Just a heads up that the Pi Zero has a camera ribbon cable slot to add a relatively inexpensive camera to the zero. It would record the rides as well as provide bike computer info.
energyi
energyi
energyi
Wed Oct 17, 2018 8:08 pm
energyi
Even less expensive route for Rpi0 video: viewtopic.php?f=63&t=224714
energyi
przemof
Wed Oct 17, 2018 8:20 pm
Interesting idea - thanks!
