alxprogramz
Problems with omxplayer on Fedberry
Sat Jul 29, 2017 10:20 pm
* failed to open vchiq instance
This is the error I get when tried to open a .mov
Any suggestion????
Command ran is
omxplayer -o hdmi -- win "0 0 640 480" myvideo.mov
Tried other as well but I still get the error "failed to open vchiq instance".
I have no idea what that means. Any help?? Reason using FedBerry is that I'm studying Fedora distros.
pcmanbob
Re: Problems with omxplayer on Fedberry
Sat Jul 29, 2017 10:46 pm
Hi.
Think you will get much better support for Fedberry on their chat page. https://gitter.im/fedberry/chat
vaughan
Mon Jul 31, 2017 11:40 am
As compared to other distros, security on Fedberry is a bit tighter and by default, won't allow access to /dev/vchiq for non root users. If you want to use omxplayer as a non root user, you will have to add the desired user to the 'video' group and then reboot. Eg.
usermod -aGvideo USERNAME
alxprogramz
Wed Aug 02, 2017 11:46 am
alxprogrogrmz
[Thank you so much. Did not know it was a security issue. I switched to root and it works. Again thank you. Now I learned something new
