Pi124
Transmission Permission denied
Wed Jul 26, 2017 2:05 am
I am getting permission denied error when I try to download files in transmission.
I have set download directory to an external FAT32 USB HDD.
I automount the HDD using the following line in /etc/fstab file
UUID=EF4E-0CFC /mnt/library vfat nofail,uid=pi,gid=pi 0 0
lmarmisa
Re: Transmission Permission denied
Wed Jul 26, 2017 2:50 am
The problem could be not related to transmission.
Are you sure the external device is correctly mounted?:
mount | grep /mnt/library
ls -l /mnt/library
echo "hello" > /mnt/library/hello.txt
ls -l /mnt/library
rm /mnt/library/hello.txt
NOTE: the most frequently directory used for mounting external devices is /media. The directory /mnt can be used too but it is not so usual. Are you sure that /mnt is correct?.
Pi124
Wed Jul 26, 2017 11:47 am
I think the problem is the external USB hdd has not been mounted properly.
Can anyone tell me how to mount it properly?
Pi124
Wed Jul 26, 2017 11:52 am
Hello.txt file was created on the USB hdd
allfox
Wed Jul 26, 2017 8:12 pm
Debian packaged Transmission would run as "debian-transmission" other than "pi": https://wiki.debian.org/BitTorrent/Transmission
So if you installed Transmission via "apt-get", you might try mount "UUID=EF4E-0CFC /mnt/library vfat nofail,uid=debian-transmission,gid=debian-transmission 0 0"
Pi124
Wed Jul 26, 2017 9:40 pm
Still getting the error..
allfox
Thu Jul 27, 2017 11:14 am
You need to tell us more.
What you did any way? We can't do telepath to know your situation, and we are lazy so we wont read your cooking recipe.
How did you installed Transmission?
What you see when doing "ls -l /mnt/library".
Pi124
Thu Jul 27, 2017 4:34 pm
I installed Transmission using sudo apt-get install transmission-daemon
I reinstalled retropie and also reformatted my USB drive to NTFS.
I gave this command in /etc/fstab to automount the NTFS USB drive. It's not working since the drive doesn't mount.
01D306E43E77DFF0 /media/library ntfs-3g nofail,uid=1000,gid=1000,noatime 0 0
lmarmisa
Thu Jul 27, 2017 4:52 pm
If the test I proposed you was successful, the USB drive is being mounted.
These commands should help (post the outputs here if you wish):
sudo blkid
ls -l /mnt/library
The command blkid will show the different unique ids of drives. Check the uuid of you USB drive is correct.
The second command will show if the USB is mounted.
If the drive is mounted, the third command will show info related to ownership and permissions (user, group, others) of the mounted root directory.
Pi124
Thu Jul 27, 2017 5:02 pm
sudo blkid
ls -l /mnt/library
The ntfs USB drive is mounting now. I forgot to include uuid= in fstab file.
Output of ls - l /media/library is
pi@retropie:~ $ ls -l /media/library
total 8
drwxrwxrwx 1 pi pi 4096 Jul 27 2017 Media
drwxrwxrwx 1 pi pi 0 Jul 27 2017 $RECYCLE.BIN
drwxrwxrwx 1 pi pi 4096 Jul 27 2017 roms
drwxrwxrwx 1 pi pi 0 Jul 27 2017 shares
pi@retropie:~ $
lmarmisa
Thu Jul 27, 2017 5:09 pm
Everything looks good. Transmission should be able to write files there. Check the configuration of transmission if the problem continues.
allfox
Thu Jul 27, 2017 8:32 pm
I think it also worth checking "ls -l /media" to tell if the "library" directory could be written by the "debian-transmission" user.
Pi124
Fri Jul 28, 2017 1:56 am
It's working now.
What finally did it was switching to ntfs from FAT32.
ageekhere
Fri Jul 28, 2017 1:10 pm
I had this problem, took a while to fix, try the following
UUID=EF4E-0CFC     /mnt/library   auto    rw,user,auto,fmask=0000,dmask=0000    0    0
lmarmisa
Fri Jul 28, 2017 4:49 pm
FAT32 or FAT16 file-systems are not suitable for storing big files due to maximum size limits.
I believe that this was your problem:
https://www.genie9.com/Support/KB/Knowl ... x?KBID=113
ageekhere
Sat Jul 29, 2017 12:59 am
I used exFAT
sudo apt-get install fuse-exfat exfat-utils
