pcmanbob
Re: NEW FORUM SKIN - Comments here please.
Tue Jul 25, 2017 3:38 pm
I don't like the new skin it looks to busy.
and I have already ground the the code tags don't work properly, just looked at one of my posts and the code box created by code tags is just a jumble of letters totally unreadable.
example
#!/bin/bash # Daily Email Script Broadband Monitor v2.00 21 may 2017 # put eamil address in line below email_addresses1="my [email protected]" email_addresses2="some [email protected]" current_time=$(date "+%Y.%m.%d") python /home/pi/makecsv.py python /home/pi/makemessage.py mv /home/pi/speed-test-results.csv /home/pi/$current_time-speed-test-results.csv mv /home/pi/speed_test_results.txt /home/pi/$current_time-speed-test-results.txt mv /home/pi/connection-results.csv /home/pi/$current_time-connection-results.csv echo "Quality %,Test Time,Failed Site Name" > /home/pi/connection-results.csv cd /home/pi zip $current_time-results.zip $current_time-speed-test-results.csv $current_time-speed-test-results.txt $current_time-connection-results.csv cd mpack -s "Broadband Monitor Results with zip file attached" -d /home/pi/message.txt /home/pi/$current_time-results.zip $email_addresses1 mpack -s "Broadband Monitor Results with zip file attached" -d /home/pi/message.txt /home/pi/$current_time-results.zip $email_addresses2 mv /home/pi/$current_time-speed-test-results.txt /home/pi/archive/ mv /home/pi/$current_time-speed-test-results.csv /home/pi/archive/ mv /home/pi/$current_time-connection-results.csv /home/pi/archive/ rm /home/pi/message.txt rm /home/pi/$current_time-results.zip
so posting code is now a total waste of time on this forum.
The font is way to big, yes I were glasses but I am not blind yet.
and it does not work on my 9" table any more columns are just overlapping each other making it impossible to read.
If this skin persists I think this forum will just die as it unusable.
Edit.
switching to rpi skin has at least reduced the font size.
but code tags still don't work.
Tue Jul 25, 2017 3:44 pm
I've switched to RPI. It's like Prosilver but without the ugly blueness. That's going to work for me.
The default "Raspberry_Pi" is exceedingly ugly compared to RPI.
This is a doctor free zone.
beta-tester
Tue Jul 25, 2017 3:47 pm
example
your code appears as one-liner.
what theme you used?
code block created with theme prosilver looks ok to me.
# 1'st line
# 2'nd line
# 3'rd line
# 4'th line
# 5'th line
# 6'th line
# 7'th line
# 8'th line
# 9'th line
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B, RPi3B, RPi3B+, RPiZeroW, ...
pcmanbob
I agree RPI is the best of the 3 poor options but without working code tags forum is going to struggle.
beta-tester
Tue Jul 25, 2017 3:53 pm
so the code block is only in theme RPI an issue.
what i don't like on theme RPI is the big spacings everywhere and the dark gray background while writing/editing a post.
mahjongg
Tue Jul 25, 2017 3:56 pm
Let me try posting code:
def ReadWatts(ser):
     global xwatts, old_xwatts, maxwatts, start_time
        xwatts = round(float(rtwatts) * 3 / 1000, 1) # you can do this like this!
        if xwatts >= maxwatts and old_xwatts < maxwatts:
            start_time = time.time()
        if xwatts < maxwatts:
            start_time = time.time() + 10000.0 # well in the future, just to be on the safe side!
        old_xwatts = xwatts
     return xwatts
     print xwatts # you can't get to anything after the return in a function
# inside the main loop
    if (time.time() - start_time) > 5.0:
        do_5s_function()
        start_time += 10000.0 # to stop repeating every loop
I've found the "Unread Posts" link. So I'm now 100% happy with the RPI skin and will stick with that.
#!bin/bash
echo "Do code blocks work?
Looks like code blocks don't work (in a nice pretty green text) on the RPI theme. Something lost the line-ends.
mahjongg
Tue Jul 25, 2017 3:57 pm
Nope you are right it doesn't work the way it should!
the people working on this skin should repair this ASAP.
[edit] well, what do you know, its fixed already!
pcmanbob
Tue Jul 25, 2017 4:00 pm
Posting this using RPI skin.
some example code with no code tags copied from notepad++ as I normally do displays as list of lines but looses all the indenting as it always has
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(38, GPIO.IN)
# main loop
while True:
# wait for button press
while GPIO.input(38) == 0:
time.sleep(0.2)
else:
# get IP address from eth0
ni.ifaddresses('eth0')
ip = ni.ifaddresses('eth0')[2][0]['addr']
iptext = str(ip)
# write IP on LCD
lcd = CharLCD()
lcd.clear()
lcd.cursor_pos = (0, 0)
lcd.write_string('Broadband Monitor Pi')
lcd.cursor_pos = (1, 3)
lcd.write_string('My IP for eth0')
lcd.cursor_pos = (3, 3)
lcd.write_string(iptext)
time.sleep(10)
now placed between code tags coped exactly the same (used to display as list of lines with correct indenting) but no longer
# main loop
while True:
		time.sleep(0.2)
	else:
		iptext = str(ip)
		# write IP on LCD
		lcd = CharLCD()
		lcd.clear()
		time.sleep(10)
mahjongg
Tue Jul 25, 2017 4:02 pm
It seems to be a raspberry_pi skin display problem, as the standard pro silver skin works.
Will alarm the people responsible immediately, so hopefully it will be fixed soon.
its a pity we didn't notice this behaviour in the test stage.
stupid teething troubles.... :mrgreen:
pcmanbob
Tue Jul 25, 2017 4:04 pm
It affects raspberry_pi and RPI skins not tried pro silver skin yet.
beta-tester
"RPI" has problems as well.
"ProSilver" is fine - no problems
beta-tester
Tue Jul 25, 2017 4:10 pm
that means nobody of the testers were using the other themes except prosilver for serious posts... :lol:
bensimmo
Tue Jul 25, 2017 4:15 pm
RPI is the nicer skin to use on my mobile. Boy's are not cut off.
The raspberry skin seems to work ok in landscape but the default mobile mobile portrait is messy.
RPI has the same code problem
RPI has the same save draft, preview, sumbit button glitch
We still need a larger image attachment as a simple screen grab on my phone to show the problems cannot be attached quickly.
mahjongg
Tue Jul 25, 2017 4:17 pm
Well, I did some preliminary tests with the new theme, and I did notice that sticky posts were initially displayed the exact same way as all other posts, (and so were unrecognisable as stickies) so I edited all sticky post subject lines to prefix them with STICKY: hoping a better solution would arrive later. And I remember having looked at some python posts but saw nothing suspicious, but I could have just missed it.
I did NOT try to post any code, unfortunately.
lets hope this can be fixed quickly.
Tue Jul 25, 2017 4:18 pm
I helped test, never saw the code problem though. My bad. And no, I didn't just test in prosilver since that a PHPBB supplied skin and therefor well tested elsewhere.
bensimmo
Tue Jul 25, 2017 4:19 pm
Oh and thanks for doing all of this, it should benefit everyone in the end :-D
Tue Jul 25, 2017 4:20 pm
The white box/unsolicited drop down appearing in the RPI skin should now be fixed.
mahjongg
Tue Jul 25, 2017 4:27 pm
Yes, I noticed it before, but its gone now.
What IS the "RPI skin"? is it just an experimental alternative skin?
bensimmo
Tue Jul 25, 2017 4:29 pm
RPI skin
Landscape there is a jump to new posts click bit (icon could be larger)
Move to Portrait and it's not there.
drgeoff
Tue Jul 25, 2017 4:31 pm
On the default theme:
I miss the 'Return to xxxx' button and the 'Jump to' drop down selection.
The reddy-brown colour is garish. The font is too large.
Permalink button is gone.
Tue Jul 25, 2017 4:42 pm
Will be the 'final' version of forum I believe - currently being developed, so not ready to replace anything yet, but needs testing. Things should go a lot faster now the new PHPBB software is in place.
Re: STICKY: NEW FORUM SKIN - Comments here please.
Tue Jul 25, 2017 4:45 pm
I think the RPI skin code blocks should now be working, not sure about raspberry yet, but worth a try.
EDIT. Should be fixed in both themes.
DirkS
Tue Jul 25, 2017 4:49 pm
dfjdfjdfjdfj
adf
df adf
Yes, seems to be working in RPI
Tue Jul 25, 2017 4:50 pm
Yes, checked it, working fine now. Thanks Web Dudes!
