steelo
PiClock problems
Fri Jul 21, 2017 1:34 pm
Hi everybody, so happy I found this forum. I’ve had this pi for about a year now and so far have installed Raspbian, retropie, took an online course to learn Python, installed a semi-working motion detection camera using ‘motion’, PiHole, and got a semi working ‘Alexa’ which would have worked better if I had a decent microphone.
Right now, I am trying to get PiClock to work properly. I have followed all of the instructions online to a ‘T’. I fear that there may be a setting in Raspbian that is off since this isn’t a fresh install like the manual calls for. The problem I’m having is that it will not display the 5 day weather forecast on the right side. I double and triple checked the API key and even reset it. The radar weather map with the ‘WU’ icon DOES appear and update. From what I understand, that indicates that the WU API key IS working. That is the MAIN issue, but other issues I’m having are that I can’t seem to get cron to successfully open PiClock upon reboot. Raspbian will load normally and then I get a popup message saying ‘PiClock is starting’…after that…nothing.
Thank you to anybody who is willing to help me!
Re: PiClock problems
Fri Jul 21, 2017 2:04 pm
What is "PiClock" and where does it come from?
You can't start GUI programs from cron. Use the LXDE autostart process.
steelo
Fri Jul 21, 2017 2:14 pm
DougieLawson wrote:What is "PiClock" and where does it come from?
https://github.com/n0bel/PiClock
A fancy clock that pulls the weather forecast and radar. Was looking to utilize an old monitor.
Fri Jul 21, 2017 2:43 pm
Create a directory if it doesn't exist cd /home/pi/.config; mkdir autostart; cd autostart;
Add this as nano piclock.desktop file in /home/pi/.config/autostart
[Desktop Entry]
Name=PiClock
Comment=Autostart PiClock
Exec=/home/pi/piclock.startup.script.goes.here
Terminal=false
MultipleArgs=false
Type=Application
Categories=Application;Development;
StartupNotify=true
https://wiki.lxde.org/en/Autostart
steelo
Fri Jul 21, 2017 3:15 pm
Thank you! Any idea why the weather isn't pulling up though?
Fri Jul 21, 2017 6:02 pm
steelo wrote:Thank you! Any idea why the weather isn't pulling up though?
I've not even looked at running that on any of my Raspberries. Might give it a go if I'm bored over the weekend.
