komarek
Bricked my Pi. don't know why
Thu Jul 20, 2017 8:29 am
hi
yesterday was a sad day
i burned my Raspberry Pi zero W and i m still trying to understand why.
this is what i did
i'm having my power source by a 12v DC and 0.3A power supply... then i used a stepdown DC-DC converter to have a 5v DC output.
i decided to send it through the usb port (i thought that it would be less dangerous than gpio way)... so i've cut a micro-usb cable and i connected the 5v to the red wire and the ground to the black wire, then i cut the 2 data-wires (green and white).
Immediately after i connected the micro usb cable the Raspberry started to produce bad smell and smoke, i couldn't see exactly where, it was around the cpu. i disconnected the supply immediately but it was too late. The Raspberry is not powering up anymore... and i'm trying to understand what really happened.
What can you tell me?
is there any test i can try to understand what happened?
thanks folks
komarek
Re: Bricked my Pi. don't know why
Thu Jul 20, 2017 8:41 am
i used this connector
screenshot 2017-07-20 alle 10.41.07.jpg (26.72 KiB) Viewed 4142 times
RaTTuS
Contact: Twitter YouTube
Thu Jul 20, 2017 8:45 am
either it was 12V
or
you swapped the +Ve and -Ve on the Micro USb
the PI0 does not have any power protection circuit
Covfefe
komarek
Thu Jul 20, 2017 8:48 am
RaTTuS wrote:either it was 12V
or
i'm 100% sure it was 5V cause i tested it.
my first doubt it was actually i've inverted VCC and GROUND on the wires..
but it's actually strange to make such a stupid mistake for me. I Threw the connector away immediately after i saw the smoke. so i couldn't check that thing after the damage.
Is that any way i can test where the problem came from now?
pcmanbob
Thu Jul 20, 2017 9:17 am
Which DC-DC converter were you using , some of them require the output to be setup before you connect it to your pi and how accurate is the meter you were using , have you tested it on a known source voltage to see if it is actually any were near accurate.
you must have either reversed the connection supplying the pi or supplied to higher voltage, only options to have caused this.
komarek
Thu Jul 20, 2017 9:45 am
pcmanbob wrote:Which DC-DC converter were you using , some of them require the output to be setup before you connect it to your pi and how accurate is the meter you were using , have you tested it on a known source voltage to see if it is actually any were near accurate.
i used this
http://www.hotmcu.com/mp1584-buck-step- ... -p-82.html
and yes. the measurement was accurate
BMS Doug
Thu Jul 20, 2017 9:58 am
So, two possibilities:
Your power supply was inverted and you put 5V onto Gnd and Gnd to 5V (Fairly unlikely as they are pretty well marked on your kit and you had tested it.
(Speculation): Your 12V 0.3A (3.6W) supply couldn't cope with the load of the pi and its power became unstable, dipping and rising as the converter drew from it. The Fluctuating 12V power supply caused the MP1584 output voltage to similarly fluctuate, rising too high and burning out the pi.
Doug.
Building Management Systems Engineer.
komarek
Thu Jul 20, 2017 10:09 am
BMS Doug wrote:So, two possibilities:
this is quite interesting
so how shall i avoid this situation in the future (assuming that this was the problem) with my new raspberry i just bought?
and is there any way to test if actually the power supply or the converter become unstable without breaking anything else?
Mortimer
Thu Jul 20, 2017 10:21 am
After watching quite a few BigClive videos on YouTube it is apparent that many USB leads coming from China cannot be trusted to have the correct colours on the power lines. He frequently finds +5V is white and ground is red.
Always continuity check such connections and make sure connections are going to where you expect them to.
The purpose of a little toe is to ensure you keep your furniture in the right place.
pcmanbob
Thu Jul 20, 2017 10:38 am
komarek wrote: this is quite interesting
Why don't you just buy a 5V pi power supply with the correct rating ?
If you want to use a 12v power supply and a DC-DC converter you are going to need a 12v 1A power supply as a minimum, I have one running a pi2 project that includes pi, 20x4 LCD and 10 LED bar graph display.
komarek
Thu Jul 20, 2017 10:43 am
Mortimer wrote:After watching quite a few BigClive videos on YouTube it is apparent that many USB leads coming from China cannot be trusted to have the correct colours on the power lines. He frequently finds +5V is white and ground is red.
oh god.
i assumed the colors were correct.
so... is there any way to check if the wires color are actually red for VCC and black for ground without breaking anything else?
komarek
Thu Jul 20, 2017 10:45 am
well
cause i need to put the PI inside a small box where i have 12V but i don't have 220V to plug the power supply you talk about... and, anyway, there would not be space enough
pcmanbob
Thu Jul 20, 2017 10:51 am
why not just buy micro usb plugs form some were like ebay and make your own leads that way you can use correctly sized wire and make sure its wired correctly.
http://www.ebay.co.uk/itm/10PCS-New-Mic ... SwXYtY07uA
plug wiring pin out http://neverstopbuilding.com/wiring-micro-usb-pinout
komarek
Thu Jul 20, 2017 10:53 am
pcmanbob wrote:why not just buy micro usb plugs form some were like ebay and make your own leads that way you can use correctly sized wire and make sure its wired correctly.
well
because it took forever to have those things shipped and i had a cable ready in my desk to do the operation...
plus: as BMS Doug said the problem could be an unstable power supply behavior
Mortimer
Thu Jul 20, 2017 10:56 am
oh god.
I would plug your DC-DC converter into the Pi without power attached, and just buzz out the connections and check that there is continuity from the +5V of the converter to the +5V GPIO pin on the Pi, and likewise for Ground.
Mortimer
Thu Jul 20, 2017 10:58 am
We have a saying "Assumption is the mother of all mistakes". The language is usually a bit stronger, bit it is a good expression to keep in mind.
I suppose to be completely PC : "Assumption is the parent of all mistakes." :D
komarek
Thu Jul 20, 2017 11:03 am
the same usb connector plugged to a chinese fan
the wires seem to be ok however
cause the chinese fan in the picture just uses 2 wires... and they have to be the 2 i've connected to a 5v power supply
pcmanbob
Thu Jul 20, 2017 11:10 am
well
Well you will need about 300mA at 5.1v to run a pi zero as an absolute minimum, which is 1.53 watts.
So your psu supplying 12v at 0.3A should be able to supply it, BUT if the psu is actually a battery charger it is quite possible that it will not supply 0.3A at 12v, to test your set-up with out risking your pi you could connect a resistance of 17 ohms ( rated at 1.5watts) and then try measuring the voltage output of your DC-DC converter.
komarek
Thu Jul 20, 2017 11:16 am
well
the PSU is actually a power supply unit for a intercom/doorbell system... it produces 12VAC and 12VDC at the same time.
ps.
The 12VAC is used to ring the bell and i already used that to switch one gpio to TRUE (with a diodes rectifier bridge and a voltage reductor circuit) and it was perfectly working...
but this is another story... and that circuit was not connected when i burned my PI
pcmanbob
Thu Jul 20, 2017 11:22 am
ps.
if you think the psu may be the cause of the problem then run the test , you may be able to use the fan as your load if it draws sufficient mA.
Don't forget your intercom/bell is using the psu as well so you may not have 12v at 0.3A available for the pi
komarek
Thu Jul 20, 2017 11:24 am
pcmanbob wrote:
ps.
the fan is connected with a battery charger system with a 5v rechargeable battery inside
sparkyhall
Thu Jul 20, 2017 4:19 pm
I have several of these dc-dc convertors and the output voltage is not stable. In my case I needed to step down from 24V to 5V for a Pi3, before connecting the Pi I set the output voltage with a dummy load resistor of 8Ω while observing the output with an oscilloscope. This revealed that the output was oscillating between around 4-6V, I can't remember the frequency of oscillation but I do recall my multi-meter showing a stable 5V, presumably due to averaging. It appears, as supplied, that these do not have a large enough output smoothing capacitor. In my case I was able to eliminate the oscillations by placing a 100uF cap on the output of the dc-dc.
If your dc-dc behaved the same as mine then it may well have been the reason for your Pi demise.
komarek
Thu Jul 20, 2017 4:24 pm
sparkyhall wrote:I have several of these dc-dc convertors and the output voltage is not stable. In my case I needed to step down from 24V to 5V for a Pi3, before connecting the Pi I set the output voltage with a dummy load resistor of 8Ω while observing the output with an oscilloscope. This revealed that the output was oscillating between around 4-6V, I can't remember the frequency of oscillation but I do recall my multi-meter showing a stable 5V, presumably due to averaging. It appears, as supplied, that these do not have a large enough output smoothing capacitor. In my case I was able to eliminate the oscillations by placing a 100uF cap on the output of the dc-dc.
i see
but excuse me one question... the Raspberry doesn't have a circuit for protection about these voltage fluctuations through the micro usb port?
The device started to burn and smoking. sounds too much for 1 or 2 volts difference
pcmanbob
Thu Jul 20, 2017 4:31 pm
komarek wrote: i see
No the pi zero does not have any input protection unlike the pi2 or pi3, and 6v - 7v would probably be sufficient to destroy the voltage regulator circuit on the pi
komarek
Thu Jul 20, 2017 4:39 pm
wow
