yasje
Distance Rasp
Sat Jul 01, 2017 6:56 pm
Hey guys,
It have been a while that i have used raspberry pi, but i heard it's out to date?
The story is: mine rasp have noobos on it and i wanna use it for the follow:
I want to use the rasp on distance, so i wanna login from anywhere in the world.
I wanna use it to watch movies with it from smart tv and i wanna login trough other desktops.
What OS do i need and what tools?
I hope you guys can help me.
Thank you.
yasje
Re: Distance Rasp
Sat Jul 08, 2017 5:59 pm
Ssh installing and maybe a vpn tunnel is the solution.
pi_everalm
Re: Distance Rasp
Sun Jul 09, 2017 7:45 am
NOOBS is just a simplified way to set up an operating system on a RPi. If you think your running operating system version is 'out of date', update it
From the command line, when connected to the internet, run
sudo apt-get update
sudo apt-get upgrade
If you want a full, new clean operating system, follow the instructions at
https://www.raspberrypi.org/downloads/
To connect to your Rip and home network remotely, install a VPN connection, as I assume from your post you are probably happier with as close to plug and play as possible, i suggest
http://www.pivpn.io/
yasje
Re: Distance Rasp
Sat Aug 05, 2017 1:28 pm
sudo apt-get update
Thank you, i gonna try it in the weekend.
thanks for the response.
Re: Distance Rasp
Sat Aug 05, 2017 5:30 pm
jasje,
You heard wrong advice.
Get your latest operating system from raspberrypi.org/downloads
