gallopingalice
USB memory sticks
Fri Sep 28, 2012 2:13 pm
I've added a 32GB memory stick to my Pi set-up.
I can read and write files to this stick using the GUI and file-manager or the Leafpad editor.
However, access is denied from the command line, root and branch.
I have missed a trick somewhere! any ideas?
gallopingalice
gallopingalice
Re: USB memory sticks
Fri Sep 28, 2012 7:26 pm
Well, who'da thought it. I can use nano and the stick IF I use the desktop terminal, but not the post login command line inputs. What can be the difference?
gallopingalice
bantu
Fri Sep 28, 2012 8:30 pm
You probably have to mount your USB stick filesystem before you can use it. Desktops usually take over mounting filesystems of removable for you.
See http://en.wikipedia.org/wiki/Mount_%28computing%29 for more background.
0117blocky
Sat Sep 29, 2012 12:30 pm
What I found which works is use a wildcard.
ls /media/* which gives you access to "USB DISK"
