foxxyman
Location: Ephraim, Utah, USA, Earth, Milky Way, Universe
low end smartphone creation
Wed May 24, 2017 3:39 am
can I just make this: https://www.instructables.com/id/Build- ... martphone/ with the raspberry pi 3 model B? the instructable was made when the first pi was made. :D:D:D:D :)
-foxxyman
The pi solves life...
Re: low end smartphone creation
Wed May 24, 2017 6:21 am
Sure, why not?
The instructions may need some reinterpreting for modern Pi, I have not looked, but I'm sure it's possible.
foxxyman
Wed May 24, 2017 6:13 pm
Heater wrote:Sure, why not?
what do you mean by reinterperting? (sorry I am a newbie :D )
-foxxyman
foxxyman
Wed May 24, 2017 6:22 pm
should I use the same instructions, in the instructable, for the rpi3, as I would for the original pi?
[I hope this makes sense :D]
-foxxyman
Wed May 24, 2017 7:17 pm
foxxyman,
...what do you mean by reinterperting?
Sorry, I was not so clear.
I simply meant that the Pi hardware has changed a bit since then. As has the operating system and other software. So any instructions from years back may not still work as is, they might need adapting here and there.
...should I use the same instructions, in the instructable, for the rpi3, as I would for the original pi?
It's a very good starting point. If you hit anything that does not work you can always ask here. If any details of the procedure need updating to get it working it would be great if you could publish your new, updated, instructions somewhere.
foxxyman
Mon May 29, 2017 1:14 am
I would also like to be able to get 3g; the FONA from the instructable is only 2g :(
-foxxyman
Mon May 29, 2017 10:50 am
foxxyman wrote:I would also like to be able to get 3g; the FONA from the instructable is only 2g :(
https://www.cooking-hacks.com/
They offer various boards, so may be of interest to you ?
Retired disgracefully.....
......to a more gentile life !
foxxyman
Wed May 31, 2017 3:25 am
-foxxyman
foxxyman
Mon Jun 19, 2017 9:10 pm
I want something like this: https://www.adafruit.com/product/1946 but that can access 3g.
What little "breakout modem thingy", that will work with the earlier mentioned instructable, would any of you guys recommend? (I am new to this stuff :D )
-foxxyman
pi_everalm
Tue Jun 20, 2017 9:59 am
I picked up and am using these two
GSM/GPRS. http://sixfab.com/product/gsmgprs-shield/
< 100kbps download and upload
3G/4G shield. http://sixfab.com/product/3g-4glte-base-shield
3G card for said shield http://sixfab.com/product/quectel-uc20- ... 3g-module/
< 15 Mbps download
< 6 Mbps upload
4G/LTE card for shield http://sixfab.com/product/quectel-ec25- ... te-module/
< 100Mbps download
< 50 Mbps upload
Both provide location services, the GPRS one via cell tower location, the 3G and 4G have GPS/GLONASS
Both provide access and use via GPIO pins or USB and are powered through GPIO or USB
The problem I am having at the moment is with the touchscreen, an old 3.5" tft resistive touch screen that appears to use a kernel update that causes problems with the boards. I'll probably bite the bullet and get a new capacitive touch one rather than continue to mess around with the old screen.
foxxyman
Tue Jun 20, 2017 3:46 pm
pi_everalm wrote: The problem I am having at the moment is with the touchscreen, an old 3.5" tft resistive touch screen that appears to use a kernel update that causes problems with the boards. I'll probably bite the bullet and get a new capacitive touch one rather than continue to mess around with the old screen.
so you are saying that the Pitft doesn't work with RPi3 at this time; so I should try another RPi3 compatible screen? (I have vaguely heard something like this before)
-foxxyman
