nh0s
[Power Supply] For a RaspBerry 3 model B
Sat May 20, 2017 4:45 pm
I would like to make a RecalBox. I'm making a Shopping Cart at the moment but I'm asking of myself if I can use my Wiko's Power-Supply to power on the RaspBerry.
I have 2 Power Supply :
- 5V - 1A (Wiko)
- 5V - 4A (but I use this very frequently) (One Plus's Dash Charge)
Can I use the first one ? If not what are you offering ?
Because I don't have a lot money, and 15€ for a power supply.. It's very expansive.
Sincerely,
Nh0s.
alphanumeric
Re: [Power Supply] For a RaspBerry 3 model B
Sat May 20, 2017 6:55 pm
1A likely isn't going to cut it. Iffy at best IMHO. The 3B draws 400ma at idle.
https://www.raspberrypi.org/help/faqs/#topPower
Then add in what ever your USB connected devices draw. Try it, if you start seeing a lightning bolt pop up on screen, you'll need something with more ma.
runboy93
Sat May 20, 2017 9:54 pm
2.5-3A
kusti8
Sat May 20, 2017 11:04 pm
I've used this one among others and it is very reliable:
https://www.amazon.com/CanaKit-Raspberr ... 1_2&sr=8-2
alphanumeric
Sun May 21, 2017 9:30 am
kusti8 wrote:I've used this one among others and it is very reliable:
I have one of those too. It powers my Media Center KODO Pi.
Pernat1y
Mon May 22, 2017 7:54 am
It is strongly recommended to read this: http://elinux.org/RPi_VerifiedPeriphera ... r_Adapters
For RPi3 there is recommended to have 2.5 Amps and up.
davidcoton
Mon May 22, 2017 8:29 am
Pernat1y wrote:It is strongly recommended to read this: http://elinux.org/RPi_VerifiedPeriphera ... r_Adapters
For RPi3 there is recommended to have 3 Amps and up.
Where do you get the 3A+ recommendation from?
The "official" PSU is 2.5A, and is sufficient for a Pi3B with "normal" peripherals. It might struggle to power a touchscreen and a hard disk at the same time, but it can cope with one or the other. However, without knowing the power requirements of the OP's peripherals, there is an element of guesswork.
Signature retired
alphanumeric
Mon May 22, 2017 9:03 am
The recommended (Pi foundation) is 2.5A not 3A and up, https://www.raspberrypi.org/help/faqs/#topPower I've run mine on 2A power supplies no problem.
Pernat1y
Tue May 23, 2017 12:58 pm
Right. Fixed.
