sfguy
Pi B+ freezes after some time when running program
Tue Apr 25, 2017 4:01 pm
Good morning!
I wanted to post a more general question to this forum as I got stuck with my Pi B+ (I consider myself as a beginner and the answer might be easy):
I am running a little code that measures the distance between an ultrasound module and an object (with hardware attached). Measurements occur every second, which is needed. The computer functions very well for some time (randomly, but in the ballpark of hours) but then all of a sudden, the program freezes. Only that particular code in that particular window is not responsive anymore. But I still can exit that problem via <CTRL>+C and restart that code. I also can still manage programs in other windows or edit code etc. while that program got stuck.
So - I was wondering if there is any buffer that gets filled up over time and which I would have to empty to avoid this problem.. ? If so, can I insert such a command in the code instead of restarting the Pi every day?
Sorry if this question sound stupid.
I changed distance reading to 1 min to stretch the time, but I really need that 1 sec interval.
Thanks in advance!
HD
pi_everalm
Re: Pi B+ freezes after some time when running program
Wed Apr 26, 2017 6:58 am
The issue may be due to logging, code issues, timing or AN Other reason, whilst you debug, a quick and dirty workaround would be to set up a cron job to run a script say every couple of hours that stops and restarts the code.
Not a fix but a workaround that should keep you up and running whilst you get to the bottom of the issue.
sfguy
Wed Apr 26, 2017 9:36 am
Hello pi_everalm,
Thanks for your reply. In this case, I surely have to do a deep debug if there is no obvious reason.
Great idea with a script run in parallel. Is there a code available somewhere (I do not know how to terminate and restart programs from another program).
Cheers,
HD
RaTTuS
Contact: Twitter YouTube
Wed Apr 26, 2017 9:45 am
run top - is the memory use growing all the time ? if so you have a memory leak ... fix your code...
or post you code and let someone abuse it to be better
see
git
Covfefe
sfguy
Wed Apr 26, 2017 12:56 pm
RaTTuS,
Thanks for your comment.
All memory I can read with du -hs or free -h does almost not change from start to freeze after a few hours.
Cheers,
HD
