henkoegema
sd card in Raspberry pi Zero-W ?
Sat Apr 22, 2017 3:54 pm
Can a sd card from a Raspberry Pi 2 be swapped into a Raspberry PI Zero-W ?
davidcoton
Re: sd card in Raspberry pi Zero-W ?
Sat Apr 22, 2017 4:00 pm
Yes, as long as it is sufficiently up to date.
Do an update/upgrade in the Pi2 first:
sudo apt update
sudo apt upgrade
Shutdown, wait, power off, move the SDCard, and it should "just work" in the Pi0W.
Signature retired
klricks
Sat Apr 22, 2017 4:02 pm
henkoegema wrote:Can a sd card from a Raspberry Pi 2 be swapped into a Raspberry PI Zero-W ?
Yes as long as you have a recent OS image. If not then you will need to update your OS image with:
sudo apt-get update
sudo apt-get upgrade
