Re: Rpi max ram
Posted: Fri Apr 21, 2017 11:08 pm
Good idea for swap is iRAM and HyperDriveHeater wrote:Swap is great till you have to use it. Then everything gets thousands of times slower.
if make it as USB storage or TF card...
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=181211
A Pi0 has 512MB of RAM. Anything beyond that (less the GPU requirments) will be swap space and--as already noted--*thousands* of times slower than physical RAM. MinecraftPi can run on a Pi0, but you probably won't much like it. On a Pi3B, it runs quite well.Frybo wrote:if u want to know wat i want to do its run mincraft on a pi 0
