I think there's a problem with the new raspbian distro.
I noticed after first write the image with DD the pi can't mount rootfs. Probably because I forgot to unmount the volumes.
Okay my bad I guess, let's try again.
It now works, doing setup and set overclock to highest settings.
Doing some code compilation etc, no problem at all > overclock seems stable.
Editing iptables and screwed the next restart... okay maybe did something wrong so let's try again.
Same story... again problems after iptables.
Now very carefully... I just finished my whole configururation. And it's time to do some performance tests.
After a short wile the pi hangs again... the OK led is constant on and the SD card has failed.
when rebooting it stops at kdb> with a lot of filesystem troubles above
I can start over again, almost a whole day lost, very frustrating
