ritika27
Dust sensor
Wed Apr 12, 2017 10:47 am
i cannot get readings from dust sensor on raspberry pi monitor. I used the dust sensor code from github. It shows error error error
.What may be the problem ??
How can i check my firmware version and how can i update my firmware ?
I attempted running firmwarecheck.py It is not displaying the version
scotty101
Re: Dust sensor
Wed Apr 12, 2017 10:53 am
Which dust sensor?
Which code did you use?
You need to be specific to get sensible answers.
ritika27
Re: Dust sensor
Wed Apr 12, 2017 11:23 am
https://www.seeedstudio.com/Grove-Dust- ... -1050.html
I use the sensor mentioned in the above link and the code is
import time
import grovepi
import atexit
atexit.register(grovepi.dust_sensor_dis)
print("Reading from the dust sensor")
grovepi.dust_sensor_en()
while True:
try:
[new_val,lowpulseoccupancy] = grovepi.dustSensorRead()
if new_val:
print(lowpulseoccupancy)
time.sleep(5)
except IOError:
print ("Error")
