fred44nl
manual update Plex Media Server
Tue Apr 04, 2017 10:05 am
when I open my browser to connect to PMS, I get a message about an update.
and the suggestion to install this update manually.
I comes as a deb-file.
found how to install this, but I do have check if it correct for my RPi.
the full file name is:
plexmediaserver-ros6-binaries-annapurna_1.5.3.3580-4b377d295_armel.deb
can I use this ??
headless RPi 3B running from usbhdd.
soydepr
Re: manual update Plex Media Server
Sun Apr 09, 2017 11:47 am
Did you try sudo apt-get upgrade
Sun Apr 09, 2017 12:04 pm
soydepr wrote:Did you try sudo apt-get upgrade
Plex Media Server is not in the repositories :D
Retired disgracefully.....
Sun Apr 09, 2017 12:08 pm
fred44nl wrote:when I open my browser to connect to PMS, I get a message about an update.
can I use this ??
The file you list is for ARMEL
The majority of the Linux Operating Systems for the Raspberry Pi are ARMHF
You have not listed any Operating System, RPi model or what you originally installed to achieve a Plex Media Server.....
fred44nl
Sun Apr 09, 2017 12:43 pm
my RPi is model 3B,running Raspbian Lite.
the initial installation involved editing /etc/apt/sources.list
in the meantime I was able to update Plex using sudo apt-get update & upgrade.
laurene001
Sun Apr 09, 2017 1:25 pm
found how to install this, but I do mutuelle retraite have check if it correct for my RPi.
can I use this ??
Hello!
Can tell me how to make a new gadget by using a raspberry pi systeme!?
Thanks!
