Pi_User100
RE: Raspberry Pi 3 Problem
Fri Mar 31, 2017 5:36 pm
Hi everyone,
I bought a Raspberry Pi 3 - (Raspbian Jessie PIXEL - 2017-03-02-raspbian-jessie.img) and I am trying to install a package called: Webmin.
I have been troubleshooting for hours, but can't seem to get it working.
I have gotten the following errors:
E: Could not get lock /var/lib/dpkg/lock - open (11 Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
E: Could not get lock /var/cache/apt/archives/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the download directory
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
[email protected]:~$ sudo dpkg --configure -a
dpkg: error: dpkg status database is locked by another process
dpkg: error processing webmin (--remove):
Package is in a very bad inconsistent state - you should
reinstall it before attempting a removal.
webmin
E: Sub-process /usr/bin/dpkg returned an error code (1).
When I try to install webmin via apt-get, it just hangs at the line:
Unpacking webmin (1.831) over (1.831)...
No matter what I do it work, I have even tried to purge, remove and reinstall the package but I keep getting the same errors.
Can anyone help me.
Would be greatly appreciated.
Thank you.
Unpacking webmin
Pi_User100
Re: RE: Raspberry Pi 3 Problem
Fri Mar 31, 2017 6:56 pm
Really need help with this.
PeterO
Fri Mar 31, 2017 7:05 pm
Pi_User100 wrote: [email protected]ubuntu:~$ sudo dpkg --configure -a
Are you running ubuntu ? If so you will probably do better by asking for help on their forums. Most people here run Raspbian.
PeterO
Pi_User100
Fri Mar 31, 2017 7:12 pm
I am running raspbian Jessie PIXEL (debian) actually.
Please can anyone help, ive been at this for hours.
Pi_User100
Fri Mar 31, 2017 8:17 pm
PeterO
Not Ubuntu.
soydepr
Fri Mar 31, 2017 9:19 pm
my recommendation learn to manage it from command line before using webmin !!!! you want to learn right ?
Pi_User100
Fri Mar 31, 2017 9:28 pm
soydepr wrote:my recommendation learn to manage it from command line before using webmin !!!! you want to learn right ?
Why won't anyone help, at this point I just want it working.
Someone here must know how to fix it. I see this post has over 300 views yet nobody wants to even comment.
soydepr
Sat Apr 01, 2017 3:20 pm
did you say what os you are using
Pi_User100
Sat Apr 01, 2017 3:47 pm
soydepr wrote:did you say what os you are using
Yes, I am using Raspbian Jessie PIXEL - latest version -> 2017-03-02-raspbian-jessie.img
martinmmps
Sat Apr 01, 2017 4:40 pm
try doing
sudo su
then
sudo apt-get install webmin
if it works then it was a problem with permissions, but i still dont see why you need to use webmin, just use terminal, its so much easier
oterwise just backup your data on a usb stick and hold shift on startup and reinstall raspian.
Ubuntu users are apt to get this joke
Pi_User100
Sat Apr 01, 2017 4:45 pm
Hey, I tried that, when I use that command I get an error message:
This is also after a fresh install of Raspbian for a second time.
It is a problem with dpkg, which I don't know how to resolve, any package I try to get wont install.
If I try to install Webmin it just hangs forever.
Even when I formatted I reinstalled raspbian with a new image the newest version it doesnt make sense.
achrn
Sat Apr 01, 2017 8:21 pm
Pi_User100 wrote: It is a problem with dpkg, which I don't know how to resolve, any package I try to get wont install.
So I think you are now saying that your problem is not actually that you can't install webmin, it's that apt-get won't install anything.
To confirm: this is a straightforward download of raspbian, from www.raspberrypi.org and installed on your pi? Have you done anything else to it after download?
Were there any errors when you went through the install and boot?
The error messages suggest something else might be accessing the packages database. Is this the only thing you're doing? That is, are you doing something like running a 'sudo apt dist-upgrade' and then jumping to another window and trying to do an apt-get in parallel?
The ,messages suggest that the process can't read /var/lib/dpkg/lock and /var/cache/apt/archives/lock. So, what do you get if you do the command 'df' (ie, is there space in your filesystem). What do you get if you do 'cd /var/lib/dpkg' and then 'ls -l'. What do you get if you do 'cd /var/cache/apt/archives' and then 'ls -l'?
Sat Apr 01, 2017 8:32 pm
Pi_User100 wrote:Hi everyone,
webmin
Can anyone help me.
Thank you.
On a fully updated Raspbian Jessie with Pixel DE use wget to install WebMin as per their website, though you will need to have an active internet connection:
http://www.webmin.com/deb.html
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
Pi_User100
Sun Apr 02, 2017 10:21 pm
Hey,
So the webmin installation did not succeed.
The webmin package was failing upon installation at 16%, so I increased the swap space but that did not fix the issue.
Although I was able to get apt-get working again but attempting to install webmin, breaks the system via dpkg.
I followed the steps from the webmin website to install on Debian.
I installed it on Ubuntu 16.10 64 bit and it worked like a charm no issues, 5 minutes.
Thanks.
