Use L293D based motor controllers to control small DC motors. Recently noticed with an 4tronix controller that even when the motor supply is disconnected, motors can still receive 0.35v or so, via L293D output. This voltage was sufficient to cause the motor to produce a little noise as though it was attempting to move. On investigation, discovered that 4.6v is seen on the unconnected motor supply terminals. This can only be due to leakage through L293D.
On checking another motor controller, (SB Components), also using L293D, found 2.75v at unconnected motor supply terminals.
None of this affects the apparent operation of the L293D, ie when logic 5v supply, and motor control 7.2v supply are both connected, everything works as expected. However, I would be interested to know if the observed leakage between the logic supply (VCC1) and the motor supply (VCC2) of the L293D is typical, or do I have damaged L293D's? I suspect the former as whilst I have seen no figures, I note that an Arduino FAQ states that "some H-bridge chips" do exhibit leakage.
