tonylcc
Just wanna ask a small thing about over clock
Thu Sep 20, 2012 12:49 pm
is it possible to overclock higher than 1GHz?
if yes, will it overheat?
if over heat, should i add some mini heatsink on it?
sry for my bad eng, I am new to here
hojnikb
Re: Just wanna ask a small thing about over clock
Thu Sep 20, 2012 3:49 pm
Yes you can manually overclock over 1Ghz. If you're lucky and dont care about the warranty you can hit 1.2Ghz with some tweaking..
Good powersupply is a must.
Dont worry about overheating, as when it hits 85C (which wont happen) it downclocks automaticly.
As for heatsinks; you dont really need one.
If you don feel paranoid, you can stick a small heatsink to lan chip, as these tend to be a bit hot when under load. But if you have the new rev2 board than even that is not need, as 1v8 bug (that causes lan chip to be hot) is fixed.
+°´°+,¸¸,+°´°~ Everyone should have a taste of UK Raspberry Pie =D ~°´°+,¸¸,+°´°+
Rasberry Pi, SoC @ 1225Mhz :o, 256MB Ram @ 550Mhz, 16GB SD-Card, Raspbian
antennas
Over clock from GUI
Thu Sep 20, 2012 4:11 pm
I just got my Pi and it boots into the desktop. Can I go back and get that menu to overclock again? I suppose you can, but how to do that?
Thanks.
pluggy
Thu Sep 20, 2012 7:49 pm
Logout of the LXDE desktop
and run
sudo raspi-config
at the command prompt
I must not tread on too many sacred cows......
antennas
Thu Sep 20, 2012 10:48 pm
Thank you sir!
