Powered USB Hub question
Posted: Wed Mar 22, 2017 12:46 am
Thank you for reading this.
I bought an El Cheepo Chinese powered USB hub some time ago and while it works perfectly it feeds 5 volts back to the host device. I haven't it used it with my Raspberry Pi because the two 5 volt power supplies will be in parellel. I was going to perform some surgury on the cable (the case is sealed) and cut the 5 volt line to the host until I read something recently that indicated that this is how powered USB hubs are normally wired but Iḿ not so sure. What do you think about this?
