Danielgn
Error while upgrade and installing
Fri Mar 17, 2017 8:33 am
Hi everyone, I am having problems with my raspberry pi 3.
When I write:
sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of systemd:
 systemd depends on libsystemd0 (= 215-17+deb8u3); however:
  Version of libsystemd0:armhf on system is 215-17+deb8u6.
 systemd depends on udev (>= 208-8); however:
  Package udev is not installed.
dpkg: error processing package systemd (--configure):
 dependency problems - leaving unconfigured
Processing triggers for man-db (2.7.0.2-5) ...
dpkg: dependency problems prevent configuration of bluez:
 bluez depends on udev (>= 170-1); however:
dpkg: error processing package bluez (--configure):
 systemd
 bluez
so I use:
sudo apt-get update
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 systemd : Depends: libsystemd0 (= 215-17+deb8u3) but 215-17+deb8u6 is installed
           Recommends: libpam-systemd but it is not installed
 udev : Depends: libudev1 (= 215-17+deb8u3) but 215-17+deb8u6 is installed
E: Unmet dependencies. Try using -f
Then:
sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  systemd systemd-sysv udev
Suggested packages:
  systemd-ui
Recommended packages:
  libpam-systemd
The following packages will be upgraded:
3 upgraded, 0 newly installed, 0 to remove and 131 not upgraded.
3 not fully installed or removed.
Need to get 3,098 kB of archives.
After this operation, 8,192 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main udev armhf 215-17+deb8u6 [850 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd armhf 215-17+deb8u6 [2,212 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd-sysv armhf 215-17+deb8u6 [36.3 kB]
Fetched 3,098 kB in 2s (1,129 kB/s)
Preconfiguring packages ...
(Reading database ... 58000 files and directories currently installed.)
Preparing to unpack .../udev_215-17+deb8u6_armhf.deb ...
And it get stopped and take me out from my connection to the raspberry.
Can anyone help me, or give me an advice por it?
Thanks.
tyo100
Re: Error while upgrade and installing
Sat Mar 25, 2017 6:51 am
Same problem, you were able to solve the problem?
tyo100
Sat Mar 25, 2017 7:14 am
Go to /var/cache/apt/archives
dpkg --force-all -i systemd-sysv_215-17+deb*.deb
apt-get -f install
and finally
apt-get upgrade
This procedure works for me
Regards :ugeek:
Electron752
Sat Mar 25, 2017 10:38 pm
I would generally avoid running a * patten on the archives directory. Who know what version you're gong to be pickup.
Sometimes the archive gets out of sync as new packages as added, so sometimes it's best to just wait awhile and try again.
tyo100
Sun Mar 26, 2017 1:01 am
You are right, my installation is new and only 1 version exists, the latest must be work.
Sorry for my english
