ElEscalador
Run Program/Script from GUI desktop without the 2nd step?
Sun Mar 12, 2017 4:15 pm
When I click on my executable script icons, I then have to choose in a popup window whether to execute, execute in terminal, open, or open with.
Is there a way to set the default to execute in terminal so I don't have to choose?
Robotics tips, hacks, book extras https://youtube.com/practicalrobotics
ElEscalador
Elescalador
Mon Mar 13, 2017 12:29 am
Man...either this is impossible or I'm really Google handicapped today and find the right query.
DavidS
Re: Run Program/Script from GUI desktop without the 2nd step
Mon Mar 13, 2017 2:09 am
It is possible. I am not sure how to do so as I launch all my programs from bash (the shell) even when running in the GUI.
ktb
Mon Mar 13, 2017 2:25 am
Hmmm...
PCManFM > Preferences > General > Don't ask options on launch executable file?
That should prevent it from prompting you, but I don't know if it will work how you want.
Edit: I guess you could make a .desktop file for it. Still not sure if that would do what you want.
script.desktop:
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=Run script in terminal
Comment=Run script in terminal
Exec=/home/pi/scripts/shell/script.sh
StartupNotify=true
Terminal=true
321
Mon Mar 13, 2017 7:18 am
A different approach.
Do you have an icon which calls the terminal and displays the behaviour you want?
Perhaps locating the Terminal icon might be a start?
treeHouse
Mon Mar 13, 2017 1:42 pm
I used the .desktop file approach, which allows you to get the script off the desktop (maybe put it in a local executables folder) and become a lxmenu item.
Here is how I launch an appimage of the latest musescore (debian stable repos have very old version). Without this, it would always ask me how I wanted this to launch.
[Desktop Entry]
Keywords=Music Notation
Name=MuseScore
Comment=Music notion editor
Exec=/home/pi/LocalApps/MuseScore-2.0.3-armhf.AppImage %F
Icon=MuseScore
Terminal=false
Type=Application
MimeType=text/plain
Categories=Education;AudioVideo;Music
This file is stored in
/home/pi/.local/share/applications
Obiously, substitute your username for pi if you created a new user.
Also, in the Exec line, the %F is an argument for saying that you can double open multiple documents of this type at a time. If this is not relevent to your script, you may omit this.
The icon line refers to a .png file named MuseScore.png which is stored in
/home/pi/.local/share/icons
Once again, substitute your user name for pi if you have created a new user account.
Hope this helps
ElEscalador
Elescalador
Mon Mar 13, 2017 3:56 pm
321 wrote:A different approach.
I guess I don't know how to make a terminal icon that also launches a behavior?
ElEscalador
Elescalador
Mon Mar 13, 2017 4:01 pm
treeHouse wrote:I used the .desktop file approach, which allows you to get the script off the desktop (maybe put it in a local executables folder) and become a lxmenu item.
[Desktop Entry]
Name=MuseScore
Icon=MuseScore
Terminal=false
Type=Application
MimeType=text/plain
Hope this helps
I don't know what most of this means but I'll seen if I can make it work! Thanks
ptamike
Re: Run Program/Script from GUI desktop without the 2nd step?
Fri Jun 19, 2020 10:18 pm
Although this is an old question, it keeps appearing in the searches but doesn't include the solution.I thought I'd correct that.
To remove the prompt when launching an executable file, do the following:
  • Open File Manager
    Select Edit - Preferences - General
    Tick the option "Don't ask options on launch executable file"
It's a simple as that!
Mike
Sat Jun 20, 2020 3:46 am
Which was already described a few posts and a few years back here.
Except that none of the Windowing systems I have on any computer have what you describe.
stubright
Sat Jun 20, 2020 9:15 am
Except where it is, exactly as described by Mike in pcmanfm.
Flan_man
Thu Aug 27, 2020 12:55 pm
  • Open File Manager
Mike
Lifesaver! So easy and sorted for me now :-)
