yash012
ibeacon detection
Fri Mar 10, 2017 5:18 am
Hi i'm new here i am working on a project , i need to detect a ibeacon on Raspberry pi 3 .
it is detected and i can see the MAC address well in Terminal using Bluetooth scan on command but i want to do that in python ,
i used this:
nearby_devices = bluetooth.discover_devices(lookup_names = True)
but in output it only shows other Bluetooth device, ibeacon is not detected.
can anyone help me on this.
PiGraham
Re: ibeacon detection
Fri Mar 10, 2017 6:29 am
This is new to me, but interesting. I found this page.
https://en.wikipedia.org/wiki/IBeacon#Technical_details
I seems an ibeacon is not like a regular BT device. Its not pairable.
That page lists an hcitool command that you try.
yash012
Fri Mar 10, 2017 11:03 am
thanks but it is not very useful as i need to detect ibeacon using python in Raspberry pi.
topguy
Fri Mar 10, 2017 11:41 am
In the Bluetooth standard, and in the chipsets, scanning for classic bluetooth devices and BLE devices ( which a beacon is ) is two different things.
Find a Python module with BLE support or use a different method if the module you are using claims to have BLE support.
PiGraham
Fri Mar 10, 2017 11:48 am
yash012 wrote:thanks but it is not very useful as i need to detect ibeacon using python in Raspberry pi.
It tells you what you have to do, what commands you have to send to scan for beacons. You can do all that from Python with system or process calls, or you can look for a Python module that handles those messages. Either way, if you read that page you should know more about what you have to do than you did before.
Even if you only used that info to check that your system can see beacons from command line you have a win. It's a very useful test of the hardware / system config.
Paul Webster
Contact: Twitter
Fri Mar 10, 2017 1:09 pm
You could try this - from 2014 (so check around for updates and alternative routes) ... it includes doing it from Python
http://www.switchdoc.com/2014/08/ibeaco ... er-python/
yash012
Sat Mar 11, 2017 6:49 am
Thanks you are right about that i did got a lot of information about ibeacon , i am able to do that in terminal using command i just now need to figure out a way to do that in Python.
Douglas6
Sat Mar 11, 2017 11:55 am
yash012
Sun Mar 12, 2017 5:40 pm
Thank you very much this is very much helpful.
yash012
Tue Mar 14, 2017 12:13 pm
i used the bluepy for detection of BLE devices , the command
sudo hcitool lescan
works very well but whenever i tried to call that in python using
BLE = subprocess.getoutput('sudo hcitool lescan')
it always shows me
Set scan parameters failed: Input/output error
, i tried restarting Bluetooth, but problem still remains.
Douglas6
Tue Mar 14, 2017 2:10 pm
Even if using subprocess correctly, that is
ble = subprocess. check_output(['sudo', 'hcitool', 'lescan'])
you'll run into the fact that lescan runs indefinitely, and that line will never return.
PiGraham
Tue Mar 14, 2017 2:19 pm
This may help
After spending a few hours working this out, I came up with this solution. The problem with hcitool lescan is that it doesn't return until it receives a SIGINT, so we send it one with Python:
    bashCommand = "hcitool lescan"
    process = subprocess.Popen(bashCommand.split(), stdout=subprocess.PIPE)
    time.sleep(3)
    os.kill(process.pid, signal.SIGINT)
    output = process.communicate()[0].
This for me returned a string containing all of the mac addresses found, after a 3 second search
http://stackoverflow.com/questions/2687 ... -to-a-file
Douglas6
Tue Mar 14, 2017 2:31 pm
Thanks for that, PiGraham. Crude, but effective.
yash012
Wed Mar 15, 2017 5:09 am
Thanks this is good, it seems that this would work very well.
yash012
Thu Mar 16, 2017 11:03 am
i have been trying to figure out this issue but nothing seems to work , it seems that
hcitool lescan
only works in terminal , it seems that it keeps running until interrupted cltr+c , well
 timeout 10s hcitool lescan
helps there in the terminal but it does not work when i try to call it in python.i tried all the suggestions in the link http://stackoverflow.com/questions/2687 ... -to-a-file i also tried bluez which is very convenient for use in Terminal but in that also after passing $ bluetoothctl , terminal goes from [email protected]:~$ to [bluetooth]#.
PiGraham
Thu Mar 16, 2017 1:58 pm
yash012 wrote:i have been trying to figure out this issue but nothing seems to work , it seems that
hcitool lescan
That's what
does, sends Ctrl-C to the process (Ctrl-C sends SIGINT).
yash012
Thu Mar 16, 2017 4:15 pm
hcitool lescan
That's what
i learned that but it did't seem to work , there must be something i am missing i will keep working on it.Thank you all for the suggestions i would like to say that i have started working on Raspberry pi recently, there is so for me to learn , this forum has been very helpful for me.
