must-be
creating a books library (adafruit guide)?
Sat Mar 04, 2017 5:10 pm
hi
i'm stuck at this stage:
https://learn.adafruit.com/digital-free ... y/overview
when i type
sudo ifdown wlan0
while using it from putty on windows it's getting stuck and i need to reboot the pi manually.
i've a wifi adapter btw.
what i did wrong?
CarlRJ
Re: creating a books library (adafruit guide)?
Sat Mar 04, 2017 7:53 pm
The command you quote shuts down the network connection that goes through the WiFi adapter. If you're ssh'd in via putty, you're essentially slamming the door shut on your own hand.
It appears those instructions were designed to be used when you're directly on the console (i.e. using a keyboard and screen connected to the Pi). On first glance, they appear to be doing substantial mucking around with the network connection (setting up an access point), so it's unlikely that there's a simple tweak to "fix" the instructions to work while you're ssh'd in over WiFi.
If using the console isn't practical, you could hook the Pi up to your network via ethernet, and ssh in that way (much easier if you're using a Pi with built-in ethernet, like a B+, 2B or 3B - if you're using a Zero, there are more hoops to jump through - a hub-with-ethernet like this or this would help - you'd only need it for setup).
must-be
Sat Mar 04, 2017 10:14 pm
let me try the cable method.
i'm using pi 2
thanks
