julyjim
USB limits on Pi 3 D-link port
Thu Feb 23, 2017 8:52 pm
Can someone confirm that only one USB port can be connected to external powered USB hub?
I am unable to use wireless USB keyboard / mouse connected to D-link USB hub UNLESS the hub is connected to specific port on Pi. Sorry- I do not know how they count, so I cannot provide better info.
I would like to record ( print) the USB error messages when the port cannot be activated. Is there a way to do that? The printout disappears after the PC runs.
Re: USB limits on Pi 3 D-link port
Fri Feb 24, 2017 7:50 am
julyjim wrote:Can someone confirm that only one USB port can be connected to external powered USB hub?
On the Raspberry Pi SBC 1B+ & 2B & 3B models all USB Ports are connected to a LAN9514 USB/Ethernet Chipset/Hub:
http://www.microchip.com/wwwproducts/en/LAN9514
dmesg can be used for driver info: http://man7.org/linux/man-pages/man1/dmesg.1.html
Last edited by fruitoftheloom on Fri Feb 24, 2017 4:45 pm, edited 1 time in total.
Thinking outside the box is better than burying your head in the sand...
julyjim
Fri Feb 24, 2017 4:06 pm
USB chip
The Raspberry Pi 3 shares the same SMSC LAN9514 chip as its predecessor, the Raspberry Pi 2, adding 10/100 Ethernet connectivity and four USB channels to the board. As before, the SMSC chip connects to the SoC via a single USB channel, acting as a USB-to-Ethernet adaptor and USB hub.
That is take from https://www.raspberrypi.org/magpi/raspberry-pi-3-specs
So same question as OP.
Why only one Pi 3 B port will connect to external hub ( D-link) and how to capture ( print / file) the initial error.
I believe this is more of USB spec question, not much to do with Pi and I won't get upset if I do not get an answer here.
It really does not matter as long as I can connect to at least one external USB hub.
Fri Feb 24, 2017 4:47 pm
Output of dmesg with Hub Plugged in ???
