Raspberry PI screen flicker
I'm a bit new to raspberry things, so I'm not entirely sure what to do here. I have RetroPie installed and running on a 5 inch car monitor. I can start up the pi with the screen working only if I unplug it a tiny bit. (http://imgur.com/66seOJw) When RetroPie starts up it's normal, all the menus work as well as the game lists. However when I select a game, it flickers nonstop. (https://www.youtube.com/watch?v=9lPatsHetwA) Can someone help me stop the flickering? And if i have to access a system file, can you tell me how to do that as well? Thanks for helping!
Re: Raspberry PI screen flicker
Are the GPUI Pins secured? Or the HDMI cable? Only time i have had that problem.... but also might be not enough power.. NEED MOAR POWER!!!!!!!
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Wrong wiring on the av cable. There are a huge variety of wirings for trrs jacks carrying audio and video. Pulling it out connects a different set of rings. https://www.adafruit.com/product/2881 is the correct wiring.
At a guess you've managed to connect between the video out and an audio out, so once any audio starts to play the video signal is rubbish.
Thanks for the quick reply, I'll order this and try it out.
