gop
RPi Zero's FCC ID missing
Sat Jan 21, 2017 4:22 pm
Hi
It's said that the RPi Zero passed FCC Part 15 "comfortably". How come there's no FCC ID printed on the board? Does it even have a FCC ID?
Re: RPi Zero's FCC ID missing
Sat Jan 21, 2017 4:38 pm
It does have an FCC id.
https://www.google.co.uk/search?q=raspberry+fcc+id
Why do you think equipment manufactured in UK/Europe and PRC needs to have external labelling?
gop
Sat Jan 21, 2017 4:43 pm
DougieLawson wrote:It does have an FCC id.
The RPi 3 Model B has one (2ABCB-RPI32). I can't find RPi Zero's. It's a Class B device since it has an onboard radio is sold to residential users.
Because it's sold in the US. Also,
"If the labelling area is considered too small and therefore it is impractical (smaller than the palm of the hand) to display the compliance statement, then the statement may be placed in the user manual or product packaging. However, the device must still be labelled with the FCC ID."
https://apps.fcc.gov/kdb/GetAttachment. ... mber=27980
Sat Jan 21, 2017 5:11 pm
Zero's don't have any on board wireless neither BT nor WiFi so should be exempt from FCC certification.
Sat Jan 21, 2017 5:15 pm
gop wrote:I can't find RPi Zero's. It's a Class B device since it has an onboard radio.
No it doesn't.
bensimmo
Sat Jan 21, 2017 5:16 pm
DougieLawson wrote:Zero's don't have any on board wireless neither BT nor WiFi so should be exempt from FCC certification.
Why does the B have it?
I think from some long boring post I skimmed over on Element that 'computing' devices all need Class B in the residential use.
But that US so they can explain whats and whys and wheres
aaronb3
Sat Jan 21, 2017 5:37 pm
Then the Zero should be no less a Class B device than the B(+).
W. H. Heydt
Sun Jan 22, 2017 3:15 am
The only B-series Pi that has built in wiFi or B/T is the Pi3B. With the original Model B, the only emissions problem found in testing (IIRC) was related to HDMI and it turned to be the fault of the cable, not the Pi.
aaronb3
Sun Jan 22, 2017 3:30 am
FCC writes:
If a digital device is sold or offered for sale to any residential users (including
commercial or industrial companies that could employ the equipment in a residential
environment) then it is a Class B digital device regardless of its price or application.
https://transition.fcc.gov/Bureaus/Engi ... t62rev.pdf
So it's not about having on board radios.
aaronb3
Sun Jan 22, 2017 3:33 am
W. H. Heydt wrote:With the original Model B, the only emissions problem found in testing (IIRC) was related to HDMI and it turned to be the fault of the cable, not the Pi.
Yeah, but why does the Model B need FCC certification whilst the Zero does not? Neither is an intentional emitter.
W. H. Heydt
Sun Jan 22, 2017 4:11 am
The FCC wants certification that they *don't* emit. *All* electronics is going to put out some EMI. The certification tests are to be sure that it is below the legal limits on specified frequency bands. For devices that are designed to emit, the tests are to show that the emissions are within the limits for both power and frequency. This is feeds into to why people who want to turn a Pi into an FM transmitter are told not to do it.
aaronb3
Sun Jan 22, 2017 10:40 am
Yes, I understand that. But the Model B needed certification even when it didn't intend to emit. Why doesn't the Zero need certification also? It could well unintentionally emit like the Model B did.
bensimmo
Sun Jan 22, 2017 11:15 am
Which means to me, the Zero being a Personal Computer under their FCC definition needs to be Class B certified.
Most digital devices are subject to FCC technical standards that limit the amount of
radio noise that can be radiated from the digital device or conducted by the digital
device onto the electrical power lines. Most digital devices must be tested and shown
to be compliant with these standards before they can be marketed. In addition,
personal computers are required to be authorized by the FCC because they have been
found to have the potential for causing interference
and (after the table that shows it needs to be certified not just verified.)
Certified devices are also required to have an FCC ID label attached to them. The
FCC ID label must be permanently marked (etched, engraved, indelibly printed, etc.)
either directly on the device, or on a tag that is permanently affixed (riveted, welded,
etc.) to the device. The FCC ID label must be readily visible to the purchaser at the
time of purchase.
It is not just about WiFi and radio's
Assuming that is the most recent revision, it is from 1996.
