Use PI as a bluetooth hub / audio multiplexer?
Posted: Tue Jan 17, 2017 7:47 pm
Has anyone herd of using a raspberry pi to combine several BT audio input/outputs into a single BT connection (eg, BT headset and mic)?
Basically I have a couple of machines, a mobile and a VOIP phone, I would like to have all of them connect to a PI and then have one headset and mic connected via BT to the PI as well.
Idea being that a single headset/mic can be used across all the devices. I have a set of BT headphones that can connect to 2 devices, but no more.
Maybe have a set of switches to pick the source, but some form of automatic switching would be better where i can set the VOIP & phone to override any others, and then PC1 to have a higher priority than PC2 etc.
Marl
Marl
