ludo75
gpio buttons
Sun Jan 01, 2017 5:19 pm
#!/usr/bin/python
import RPi.GPIO as GPIO
import os
GPIO.setmode(GPIO.BCM)
GPIO.setup(8, GPIO.IN, pull_up_down=GPIO.PUD_UP)
input = GPIO.input(8)
while True:
    GPIO.wait_for_edge(8, GPIO.RISING)
    os.system("pkill thing;/home/pi/thingy&")
GPIO.cleanup()
The above is part of alot more, but somewhere in the above lies the problem:
/home/pi/thingy starts thing, and the problem is that when i push "8" i get two instances of thing.
Nothing crucial like the control of nuclear facilities, but anyway i'd like to stop at one instance.
i've added "pkill thing" in /home/pi/thingy in two places a line 1 and just before i start "thing" at the end
btw thing is and audioplayer
do yall get the thing ;)
mahjongg
Re: gpio buttons
Sun Jan 01, 2017 5:24 pm
sounds like contact bounce, your switch is producing more than one flank.
ludo75
Re: gpio buttons
Sun Jan 01, 2017 5:38 pm
what do i do about it, switch out the buttons?
davidcoton
Re: gpio buttons
Sun Jan 01, 2017 6:52 pm
There's a LONG thread about it here somewhere, I'm sure Google can find it if no-one knows the reference offhand.
Long story short, there are hardware fixes and software fixes. Quick hardware fix is to put a small capacitor (10nF or 100nF) between the GPIO and ground. If that doesn't work, find that thread.... :lol:
Signature retired
jondallimore
Re: gpio buttons
Sun Jan 01, 2017 6:55 pm
put a pullup or pulldown resistor into the switch circuit to keep it high or low when switch is not pressed, or a small capacitor to debounce the switch
or - not sure of programming, but could it launch 'thingy' and then wait for the GPIO to change state again before continuing - ie, push switch GPIO goes high, thingy is launched, wait half a second or so, then continue program only when GPIO goes low?
bensimmo
Re: gpio buttons
Sun Jan 01, 2017 7:34 pm
Have a look at using GPIOZERO https://gpiozero.readthedocs.io (recent Raspian images come with it), it works well and has a lot of button stuff and bounce times.
ludo75
Re: gpio buttons
Sun Jan 01, 2017 10:57 pm
jondallimore wrote:put a pullup or pulldown resistor into the switch circuit to keep it high or low when switch is not pressed, or a small capacitor to debounce the switch
a waitstate it is at first :)
alexeames
Re: gpio buttons
Mon Jan 02, 2017 9:43 am
Just add
, bouncetime=300
to your wait for edge command
The other thing that jumped out at me was you are waiting for a rising edge and using a pullup at the same time. So technically you are not detecting a button press, but a button release. I don't know if it matters or makes any difference at all. Just thought I'd mention it.
Alex Eames RasPi.TV, RasP.iO
