fr4m3s
Need help with Pi3 temperature management
Tue Dec 27, 2016 5:21 pm
First of all, I am not aware of how to monitor the Pi3's temperature in real-time. so far I've been using the following command:
/opt/vc/bin/vcgencmd measure_temp
For some reason, my Pi3 idles around 58 degrees celcius (low 60s when doing some browsing and minor tasks). I thought this to be odd because for one, I am not overclocking, nor is my home very hot. I keep it between 70-75 F in my house and the Pi is in an open space with heatsinks attached.
I've noticed when I am watching YouTube videos (via Iceweasel, if that matters) in 1080p (even when not in full screen) the Pi3 temp jumps to over 82 degrees celcius. I am using a 49" Samsung 4K TV as my display; could this be pushing the Pi3 to idle so high and begin to overheat when streaming YouTube videos?
I watched a video of someone testing their Pi3 running Quake 3. They did not use heatsinks in the beginning of the test. Running Quake 3 for extended periods of time only pushed the temp to 79 degrees C. I am not sure how to measure legacy graphics in a fps game vs. 1080 video on YouTube but those results peaked my interest. He got it down to 75 degrees C with a "cheap 1 dollar heatsink". I am using the heatsinks that came with the Pi3 Canakit (from Amazon) which did have some thermal paste included.
So my question is, does something seem off with my temperatures? I am tempted to remove the heatsinks and re-apply arctic silver but I'm afraid of damaging the unit somehow when attempting to remove the (possibly well-stuck) heatsinks from the chips.
Are there any popular cooling solutions for the Pi3 currently in circulation? Thanks for any help/advice/comments that can be provided :mrgreen:
Re: Need help with Pi3 temperature management
Tue Dec 27, 2016 8:43 pm
You can ignore the RPi temp until it reaches 85°C (185°F) at which point it will throttle back until the temp reduces.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
ag123
Wed Jan 04, 2017 12:46 pm
there are many threads and articles about the 'fire breathing pi 3' :lol:
http://makezine.com/2016/03/02/raspberr ... atch-fire/
accordingly 80 degrees from
may literally be 100 deg C measured on the surface
here is what i'm doing,
viewtopic.php?f=63&t=144391&p=1085201#p1085201
in the same thread other user contributed their solution
^^^ i think this other user did a better solution than mine by using a much better heat sink and a large fan
simply having a heatsink delays the temperature rise but if the heat is not removed temperature may keep rising until the cpu throttles back
to remove all that heat, in addition to a good heat sink, a fan is needed
if it is enclosed in a box, you may even need to design in a high volume air flow to be sure that the heated air is ejected out of the box
imho, i'd rather have the current good performing but hot running pi 3 than have a slow cpu & there's the fun to try to cool it down with all that cpu cooling hacks, it's probably very much the fun similar to overclocking :lol:
faramon
Wed Jan 04, 2017 1:26 pm
Hi, you can read my solution for similar situation.
I buy heat sinks and fan for 5V from ebay.
Then I create a Python script that measure CPU temp and if it raises to xy degrees then it starts fan.
When fall to xz °C then stop cooling.
You will need to put some electronic in there to prevent GPIO from burning. It is done with transistor and resistor. Transistor is switch that receive GPIO signal and then switch 5V from Raspberry Pi to FAN..
This is post about how to do that but in °C not in F:
viewtopic.php?f=63&t=152700&p=1000845&h ... n#p1000845
and script is running on reboot or starting Raspberry Pi:
    #!/usr/bin/python
    import sys
    import time
    import datetime
    import subprocess
    import RPi.GPIO as GPIO
    FAN_PIN      = 23 #GPIO23 = PIN16
    TEMP_HIGH    = 70
    TEMP_LOW     = 48
    SLEEP_SEC    = 1 # sleep for loop
    LIMIT_SEC    = 220 #seconds
    COUNTER      = 0
    IS_FAN_ON    = 0
    CNT          = 0
    current_date = datetime.datetime.now()
    TMP_TEMP     = 0
    def GPIOsetup():
            print str(current_date)
            print "INITIALIZING..."
            GPIO.setwarnings(False)
            GPIO.setmode(GPIO.BCM)
            GPIO.setup(FAN_PIN, GPIO.OUT)
            print "SETTING FAN..."
            fanOFF()
            print "---------------"
    def fanON():
            GPIO.output(FAN_PIN, 1) #fan on
            print "FAN ON..."
    def fanOFF():
            GPIO.output(FAN_PIN, 0) #fan off
            print " "
            print "FAN OFF."
    GPIOsetup()
    while True:
            try:
                    CNT += 1
                    if CNT == 1000000:
                            CNT = 0
                    temperature_int = float(subprocess.check_output(["/opt/vc/bin/vcgencmd","measure_temp"]).replace("temp=","").replace("'C",""))
                    if temperature_int > TMP_TEMP:
                            TMP_TEMP = temperature_int
                            print "Max.temp. = "+str(temperature_int)+" - "+str(current_date)
                    if temperature_int >= TEMP_HIGH:
                            if IS_FAN_ON == 0:
                                    #Start cooling fan
                                    if COUNTER == 0:
                                            COUNTER = 1
                                    print str(COUNTER)
                                    print str(temperature_int)
                                    fanON()
                                    IS_FAN_ON = 1
                                    CNT = 1
                                    COUNTER += 1
                    else:
                            if temperature_int <= TEMP_LOW:
                                    if IS_FAN_ON == 1:
                                            fanOFF()
                                            IS_FAN_ON = 0
                                            CNT = 1
                                            print "Temperature: " + str(temperature_int)+" - "+str(current_date)
                    #If FAN is ON for a while then set FAN OFF
                    if  CNT%LIMIT_SEC == 0:
                        if IS_FAN_ON == 1:
                            fanOFF()
                            IS_FAN_ON = 0
                            CNT = 1
                            print "FAN sets OFF after continuous running!"
                            print "----------------------------------------"
                    time.sleep(SLEEP_SEC)
            except KeyboardInterrupt:
                    print " Quit"
                    GPIO.output(FAN_PIN,0)
                    GPIO.cleanup()
            except Exception as e:
                    print "ERROR: ", sys.exc_info()
                    fanOFF()
                    GPIO.cleanup()
            except:
                    print " Quit from except!"
                    GPIO.cleanup()
    print " Quit from end!"
    GPIO.cleanup()
Here is the sheme:
You have to Buy flyback diode 1N4001 and put it like in shema to prevent returning current to overburn GPIO...
ElEscalador
Wed Jan 04, 2017 1:43 pm
I have two that do overheat and throttle - possibly worse than throttling is they start to drop their wifi connection when hot (mostly happens because I'm using one to VNC into the other running heavy programs). I didn't want to sacrifice GPIO pins because they are needed for other things, so I bought a digispark microcontroller for $2 and am using that to pwm/control fan speed with a temperature sensor stuck to the heat sink. On/off bothers me - I'm not sure the rapid cooling is bad for the PI, but I'm not sure it's good for it either - I prefer to maintain a tighter, gentler temperature control.
My Autonomous Robot Project and a few of my other projects below.
https://lloydbrombach.wordpress.com/
ag123
Wed Jan 04, 2017 2:03 pm
pi 3 is fun because u don't really need to overclock it, it is pushed to the performance limits (similar to overclocked) & u'd just need to find the solution to cool it down :lol:
aislanmds
Sun Oct 14, 2018 7:45 pm
Faramon,
I'd like to use your script and make an equal system to cool my pi. I want to know if I can use a relay module in place of the transistor. In this way, the GPIO port activates the relay allowing power to the fan.
Thanks!
https://www.raspberrypi.org/forums/view ... n#p1000845
    #!/usr/bin/python
    import sys
    import time
    import datetime
    import subprocess
    TEMP_HIGH    = 70
    TEMP_LOW     = 48
    COUNTER      = 0
    IS_FAN_ON    = 0
    CNT          = 0
    TMP_TEMP     = 0
    def GPIOsetup():
            fanOFF()
    def fanON():
            print "FAN ON..."
    def fanOFF():
            print " "
            print "FAN OFF."
    GPIOsetup()
    while True:
            try:
                    CNT += 1
                    if CNT == 1000000:
                            CNT = 0
                            if IS_FAN_ON == 0:
                                    #Start cooling fan
                                    if COUNTER == 0:
                                            COUNTER = 1
                                    print str(COUNTER)
                                    fanON()
                                    IS_FAN_ON = 1
                                    CNT = 1
                                    COUNTER += 1
                    else:
                                    if IS_FAN_ON == 1:
                                            fanOFF()
                                            IS_FAN_ON = 0
                                            CNT = 1
                        if IS_FAN_ON == 1:
                            fanOFF()
                            IS_FAN_ON = 0
                            CNT = 1
                    print " Quit"
                    GPIO.cleanup()
                    fanOFF()
                    GPIO.cleanup()
            except:
                    GPIO.cleanup()
    GPIO.cleanup()
Here is the sheme:
faramon
Mon Oct 15, 2018 9:34 am
Hi, you can use relay if you connect FAN direct to 5V source through relay, I do not see the problem.
But do not connect FAN to GPIO directly...
Faramon
davidcoton
Mon Oct 15, 2018 4:18 pm
Are you using a ready-built Pi-compatible relay board, or a bare relay? A relay by itself probably won't work from the GPIO, it will need a transistor to drive it. At that point the relay is unnecessary because you can choose a transistor that will drive the fan directly.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
Imperf3kt
Mon Oct 15, 2018 8:16 pm
You don't need a transistor to control the relay, you can use a regular SPDT switch.
You lose the automated part of the process, but it does the same trick.
Stop plugging your fan directly into the GPIO 5v
https://www.electronics-tutorials.ws/power/transient-suppression.html
davidcoton
Mon Oct 15, 2018 8:40 pm
But if you use a switch, so it is a manual process, you don't need a relay. The switch can control the fan directly.
Imperf3kt
Mon Oct 15, 2018 8:59 pm
Though of that one also, but only after I had posted xD
Just get a transistor, they're cheap if you buy in bulk. Ebay usually has packs of ten for a few bucks including postage.
Make sure to use one that can handle the current.
For example, I use a fan on one project that draws 150mA, so I switch it using a 2N2222 transistor, capable of switching 200mA
LTolledo
Mon Oct 15, 2018 9:27 pm
Ok here's my take on your problem:
1. To monitor RPi's temperature in real time in Raspbian Stretch with desktop, enable the temperature monitor plugin to the top right panel
  • a. right click on the top right panel
    b. on the "Panel Preferences" window select "Panel Applets" tab
    c. click on the "Add" button
    d. in the "Add plugin to panel" scroll down and select "Temperature Monitor" and click the "Add" button.
    e. use the "Up" or "Down" button to position the plugin to your desired position.
2. To bring down the temperature, attach heatsink and fan
  • a. am using bigger heatink 20x20x6 heatsink, attached using thermal paste (not the double sided thermal tape)
    b. fan power source is tapped from the 5v microUSB port (not on the 40-pin GPIO, thereby by-passing RPi's internal power circuits). the fan is always ON when there is power from the microUSB cable. No need for "fancy" control circuits for the fan.
on this RPi3B+ am using now to post to this forum, the temperature reads 37C at an ambient of 27C. The highest temperature attained was 45C at an ambient of 33C.
this is the same solution that I applied on my RPi3B that this RPi3B+ replaced. its reading 39C at an ambient of 27, and the heatsink is still attached using a double sided thermal tape on that one. Will change to thermal paste later in the month.
Some people be like:
