John Stabler
Re: OpenGL Maximum Texture Size
Fri Dec 09, 2011 12:01 pm
I was just wondering if anybody has tinkered with OpenGL on the RP? For instance, what is the maximum texture size supported? Video modes etc...
Thanks!
ross
Fri Dec 09, 2011 5:34 pm
It ought to be very similar to what is reported here:
http://www.glbenchmark.com/phonedetails ... stgroup=gl
e.g. GL_MAX_TEXTURE_SIZE 2048
John Stabler
Fri Dec 09, 2011 8:57 pm
Thanks for the link, ross. That\'s good news for me and probably a lot of other game developers.
Fri Dec 09, 2011 9:56 pm
I\'ll try and remember to check this when I have time, but the 701 uses the same GPU so is going to be around that size (although does depend on the build I think).
gladoscc
Sat Dec 10, 2011 4:05 am
Wait, what? GL_MAX_LIGHTS is FOUR? OpenGL specs require at least 8.
kme
Sat Dec 10, 2011 4:20 am
[quote]Quote from gladoscc on December 10, 2011, 04:05
Wait, what? GL_MAX_LIGHTS is FOUR? OpenGL specs require at least 8. [/quote]It also says eight in the above link.
gladoscc
Sat Dec 10, 2011 4:27 am
[quote]Quote from kme on December 10, 2011, 04:20
Wait, what? GL_MAX_LIGHTS is FOUR? OpenGL specs require at least 8. [/quote]It also says eight in the above link.[/quote]
Ahh, I\'m sorry, I somehow misread :(
paddyg
Thu Jan 31, 2013 4:30 pm
Has anyone ever run into an issue with textures greater than 1024x1024 on the rpi? The reason I ask is because I'm trying to do 'exact' rendering of images as part of the pi3d library and they 'go wrong' when I try and use larger images. I have taken out anything from our code (I think) that might be trying to rescale the image.
If people say they have used bigger textures then I will continue searching for a bug in my code.
[Shader code on https://github.com/tipam/pi3d/blob/inte ... 2d_flat.fs might be hard going out of context]
PeterO
Thu Jan 31, 2013 4:57 pm
paddyg wrote:Has anyone ever run into an issue with textures greater than 1024x1024 on the rpi? The reason I ask is because I'm trying to do 'exact' rendering of images as part of the pi3d library and they 'go wrong' when I try and use larger images. I have taken out anything from our code (I think) that might be trying to rescale the image.
What does GlGet for GL_MAX_TEXTURE_SIZE return ?
PeterO
PeterO
Thu Jan 31, 2013 7:44 pm
Bad form to reply to ones own post I know.... but .... GL_MAX_TEXTURE_SIZE=2048
Have you tried increasing the amount of RAM assigned to the GPU ?
PeterO
paddyg
Thu Jan 31, 2013 8:06 pm
Peter, yes I did that straight away but the khronos manual says something not very assuring like "value gives a rough estimate of the largest texture that the GL can handle" So if 2048 is 2^(11 +/- 2) it could be too big at 1080!
A very good idea to increase the gpu memory, will try that now.
paddyg
Thu Jan 31, 2013 11:12 pm
Memory was already at 128 and increasing it further made the poor thing grind to a halt! 128MB must be big enough for just one 1080x1080 image (ought to fit 30).
Tried various other things and I just can't get it to render nicely.
dextrus
Thu Jan 31, 2013 11:20 pm
You are all using OpenGL ES2.0 right?
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
paddyg
Fri Feb 01, 2013 8:43 am
Dextrus, not sure about *all*, but I am
PeterO
Fri Feb 01, 2013 9:26 am
openGL ES 2.0 here.
PeterO
