B.Goode
STICKY: X86 Debian Jessie with PIXEL desktop for PC and Mac (obsolete)
Wed Dec 21, 2016 9:32 am
You know those posts that crop up from time to time that ask "Can I run Raspbian on my PC?"
Well you still can't.
But this might come close enough for a lot of people: https://www.raspberrypi.org/blog/pixel-pc-mac/
mahjongg
Re: PIXEL FOR PC AND MAC
Wed Dec 21, 2016 9:41 am
changed to sticky for now...
Nathalia21
Wed Dec 21, 2016 11:32 am
Raspberry has pins. How i can connect sensors to my Mac if i run it in my Mac?
B.Goode
Wed Dec 21, 2016 11:41 am
Nathalia21 wrote:Raspberry has pins. How i can connect sensors to my Mac if i run it in my Mac?
Literally, you can't. But you can control the gpio pins on a 'remote' RPi from a script on your Mac, like this: https://mobile.twitter.com/ben_nuttall/ ... 1449791488
Links to: https://gist.github.com/bennuttall/5727 ... da1bdc813e
Wed Dec 21, 2016 12:13 pm
Run pigpiod on your Raspberry, run a pigpio (client) on your remote system. Joan added networking to that wonderful GPIO pin control system she's built.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Wed Dec 21, 2016 12:17 pm
Apart from the suggestions above, you don't. Use the Raspberry if you want GPIO.
Please direct all questions to the forum, I do not do support via PM.
mikerr
Wed Dec 21, 2016 12:43 pm
Booted straight up on my mid 2009 Mac Book Pro
- had to toggle wifi off/on in the top bar to get it to scan though
(I've had the same happen on a pi3, so might be a pixel issue)
Ryanteck has rtk.gpio board available shortly to use Pi HATS etc on a PC / MAC
https://www.kickstarter.com/projects/ry ... escription
bensimmo
Wed Dec 21, 2016 1:15 pm
That just means my MagPi is late and I've still not got my Zero for the renewed subscription.
Time to complain :-( well a quick query email :-)
Edit/They do respond quickly.
Plus I don't have DVD players in my computers.
Will have to do it the old fashioned way of sticking it on a pendrive :-)
spl23
Wed Dec 21, 2016 1:44 pm
mikerr wrote:- had to toggle wifi off/on in the top bar to get it to scan though
It only scans very intermittently if the wifi menu is closed - if you open the wifi menu, the frequency of scans significantly increases. Try just leaving the wi-fi menu open for 30 seconds or so.
r3d4
Wed Dec 21, 2016 1:58 pm
Literally, you can't. But you can control the gpio pins on a 'remote' RPi from a script on your Mac, like....
:? speculatively,.. with a pi-zero and some kind of otg mode module/driver ?
Wed Dec 21, 2016 2:01 pm
Yep RPi 0 Gadget Mode: http://blog.gbaman.info/?p=791
Adieu
Pithagoros
Wed Dec 21, 2016 2:10 pm
Deleted, just noticed info already posted.
Wed Dec 21, 2016 2:21 pm
Pithagoros wrote:If you want to control GPIO pins from a desktop PC then you need something like this: ...
pigpiod (already installed)
pigpio (already installed)
http://abyz.co.uk/rpi/pigpio/python.html
http://abyz.co.uk/rpi/pigpio/sif.html
MQTT Evangelist
r3d4
Wed Dec 21, 2016 2:26 pm
fruitoftheloom wrote: Yep RPi 0 Gadget Mode: http://blog.gbaman.info/?p=791
Strangely the appears to be the cheaper option !
https://github.com/RPi-Distro/python-gpiozero - "A simple interface to GPIO devices with Raspberry Pi"
remotegpio.md wrote: install GPIO Zero on a PC and create objects referencing GPIO pins on a Pi over the network.
scruss
Wed Dec 21, 2016 4:15 pm
… or use any of the more traditional options like Arduino+Firmata, Flyfish FF32, ESP8266/ESP 32 over wifi, etc …
Wed Dec 21, 2016 4:28 pm
I got this to boot in a Oracle VirtualBox first go, straight from the ISO. Couldn't get a USB stick created with Etcher to boot on my lappy, so I'm trying UUI to see if that one will work. If that doesn't work I'll try dd'ing the ISO to my USB stick on a real Raspberry.
https://www.pendrivelinux.com/universal ... -as-1-2-3/
MQTT Evangelist
rubikwizard
Wed Dec 21, 2016 5:19 pm
I have an 8 year old PC with a Gigabyte P35-DS3L motherboard, Intel Q6600 processor, NVIDIA GT640 graphics and 4GB RAM.
It boots to Pixel from USB okay, however there is no menu bar at the top (it flickers briefly when starting up, but then disappears). The rest of the desktop is fine e.g. right-click/preferences etc. I can change the menu position from top to bottom but makes no difference.
ShiftPlusOne
Wed Dec 21, 2016 5:23 pm
rubikwizard wrote:I have an 8 year old PC with a Gigabyte P35-DS3L motherboard, Intel Q6600 processor, NVIDIA GT640 graphics and 4GB RAM.
Try removing the volumealsa plugin from the panel and restarting the panel.
rubikwizard
Wed Dec 21, 2016 5:29 pm
ShiftPlusOne wrote:Try removing the volumealsa plugin from the panel and restarting the panel.
Thanks. How would I do that?
ccpetersen
Wed Dec 21, 2016 5:52 pm
Alas no luck on an iMac. No boot option. Would running rEFInd help?
Model Name: iMac
Model Identifier: iMac7,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 4 MB
Memory: 6 GB
Bus Speed: 800 MHz
Boot ROM Version: IM71.007A.B03
SMC Version (system): 1.21f4
spl23
Thu Dec 22, 2016 8:50 am
Open a terminal (Ctrl-Alt-T)
Launch Geany to open the lxpanel configuration file - geany ~/.config/lxpanel/LXDE-pi/panels/panel
Find the section which looks like
Plugin {
  type=volumealsa
  Config {
Delete it
Save and restart
spl23
Thu Dec 22, 2016 8:51 am
ccpetersen wrote:Alas no luck on an iMac. No boot option. Would running rEFInd help?
It certainly won't hurt - worth a try. Please let us know if it does make a difference!
mikerr
Thu Dec 22, 2016 9:38 am
I am using rEfind on my 2009 MBP, and pixel ran OK (usb).
Not sure if it's required for USB boot but it's definitely required for me to boot off an SD card - that's why I use it
It stays at a black screen with blinking cursor at top left for 10-15 seconds on boot though (at first I thought it had failed there but it does continue)
[edit] imaged an SD card and that works fine in the MBP too (still with boot delay - but ok)
rubikwizard
Thu Dec 22, 2016 11:01 am
Plugin {
  type=volumealsa
  Config {
Delete it
Save and restart
Thank you. All sorted and working now, although I have no sound. Really fast and smooth! Would be great to see a HDD install-able version.
Return to “Raspberry Pi Desktop for PC and Mac”
Who is online
Users browsing this forum: No registered users and 0 guests
