bullen
Chromium tab crashes if video
Sat Dec 17, 2016 4:46 pm
I have the latest 4.9... kernel and chromium crashes with video, I installed rpi-chromium-mods package... how can I make chromium use omxplayer or ffmpeg?
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
Re: Chromium tab crashes if video
Sun Dec 18, 2016 10:07 am
bullen wrote:I have the latest 4.9... kernel and chromium crashes with video, I installed rpi-chromium-mods package... how can I make chromium use omxplayer or ffmpeg?
viewtopic.php?f=66&t=163018&p=1054095
There have been some issues with the above, since the chromium-browser [Version 51.0.2704.91 Built on Ubuntu 14.04, running on Raspbian 8.0] was included in "Raspbian Jessie with Pixel DE" (presuming that is your Operating System)
Kernel 4.9 is still in testing: viewtopic.php?f=29&t=167934&p=1082917
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
bullen
Sun Dec 18, 2016 4:05 pm
Thx!
guysoft
Wed Dec 28, 2016 1:45 pm
Hey, I have the same issue, and I am using 4.4.34-v7+ and Chromium Version 51.0.2704.91
Its a bug I can see on FullPageOS RC1,
if you want to reproduce it you can downlong our RC1 image here:
https://github.com/guysoft/FullPageOS/issues/92
Steps to reproduce (happends also in current base image, no need for new kernel):
1. Download:
http://docstech.net/FullPageOS/nightly/ ... .0_RC1.zip
md5:
http://docstech.net/FullPageOS/nightly/ ... C1.zip.md5
(or you can build devel branch from https://github.com/guysoft/FullPageOS)
2. Set up wifi/connect to ethernet
3. After boot vnc, or press ctrl+tab to open a new chromium window (Chromium starts at boot)
4. Put the URL:
https://graftechnology.s3.amazonaws.com ... ablet9.mp4
Expected: video should play
Result: get an "awww snap" page
Notes: if you add the tab to FullPageDashboard, and the tab is not selected, you can hear the video playing, but once you switch to it so it becomes visable it crahes.
dkines
Wed Dec 28, 2016 2:51 pm
I am new to the Raspberry Pi. I am impressed with the Pi3 but I am experiencing a few issues with the Chromium browser. I have read a number of posts on this forum and it is not clear to me how I can report issues.
What is the best way to report issues with Chromium?
The problem I am having occurs when I play a You Tube video in full screen mode. The video will pause every 5 seconds for about 1 second and then resume. If I play the video in non-full-screen mode, it plays fine.
I am running an unmodified (not updated) image of Raspbian with Pixel. I downloaded the image using NOOBS on December 25, 2016.
This is the "About" information from Chromium:
"Version 51.0.2704.91 Built on Ubuntu 14.04, running on Raspbian 8.0"
kusti8
Wed Dec 28, 2016 4:04 pm
guysoft wrote:Hey, I have the same issue, and I am using 4.4.34-v7+ and Chromium Version 51.0.2704.91
1. Download:
md5:
4. Put the URL:
Is anything being reported in the terminal?
kusti8
Wed Dec 28, 2016 4:06 pm
dkines wrote:I am new to the Raspberry Pi. I am impressed with the Pi3 but I am experiencing a few issues with the Chromium browser. I have read a number of posts on this forum and it is not clear to me how I can report issues.
This is the best place. Full screen is a bit problematic and may result in some stuttering. Anything reported when run from the terminal? H264ify extension is there?
guysoft
Thu Dec 29, 2016 10:17 am
1. Download:
md5:
4. Put the URL:
Yes! Thats where the errors are reported:
Says:
libGL error: MESA-LOADER: failed to retrieve device information
(chromium-browser:1964): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
/usr/bin/dbus-launch terminated abnormally without any error message
Received signal 8 <unknown> 000000000038
#0 0x00005535e098 base::debug::StackTrace::StackTrace()
#1 0x00005535dfe8 base::debug::(anonymous namespace)::StackDumpSignalHandler()
#2 0x000075b941a0 <unknown>
[end of stack trace]
ktvoelker
Thu Feb 09, 2017 11:41 pm
I am seeing the same issue as guysoft on a stock Raspbian image running on a Raspberry Pi 3. Here are the details I have collected:
Chromium logs:
(chromium-browser:1292): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Received signal 8 <unknown> 000000000004
#0 0x000055381098 base::debug::StackTrace::StackTrace()
#1 0x000055380fe8 base::debug::(anonymous namespace)::StackDumpSignalHandler()
#2 0x000075c181a0 <unknown>
uname -a: Linux raspberrypi 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
chromium-browser --version: Chromium 51.0.2704.91 Built on Ubuntu 14.04, running on Raspbian 8.0
config.txt:
dtparam=audio=on
dtoverlay=vc4-kms-v3d
If anyone has more information about this or would like more information from me, I would love to hear from you. Thanks!
Fri Feb 10, 2017 6:07 pm
There will be an updated chromium-version browser soon
viewtopic.php?f=63&t=174021#p1111669
adieu
Cvcolod
Mon May 22, 2017 10:40 am
I have the same issue since i've updated the kernel chromium crashes when video or sound is played,
Is there a way to fix it ?
Thanks and best,
David
guysoft
Fri Jun 23, 2017 10:10 pm
fruitoftheloom wrote:There will be an updated chromium-version browser soon
New browser still does this.
guysoft
Tue Sep 19, 2017 12:35 pm
It seems that chromium 60/Stretch does not do this anymore. I am not 100% I am running the same tests, but you guys are welcome to test and report too.
runboy93
Tue Sep 19, 2017 5:05 pm
Latest Chromium revision, 89.1010 fix some video crashes, but remember it's RPi!
smokingwheels
Tue Sep 19, 2017 7:36 pm
Just out of interest How many of your Pi's have black heatsinks?
I found after 4-5 hours of full screen videos my Pi's without heatsinks used to lockup.
Also I have set 272 mb of video memory in the Raspberry Pi Configuration page.
You can right click on a youtube video and select Stats for Nerds and it gives a result for dropped frames as the video is playing.
The other browser is called Web it looks to have slightly better video performance but does not support tabbed browsing like Chromium does.
