davidtuti
fs root at 100%. I can't see why?
Thu Dec 15, 2016 12:03 pm
I have a rasp 2 with jessie.
S.ficheros     Tamaño Usados  Disp Uso% Montado en
/dev/root         15G    14G   44M 100% /
But If I search I can't see why is full
. 757,4GiB [##########] /home
    2,5GiB [          ] /usr
  348,1MiB [          ] /lib
. 261,3MiB [          ] /var
  147,4MiB [          ] /opt
   20,7MiB [          ] /boot
   20,1MiB [          ] /boot.bak
.  15,0MiB [          ] /etc
    8,0MiB [          ] /bin
    7,6MiB [          ] /sbin
. 700,0KiB [          ] /run
.  64,0KiB [          ] /tmp
!  16,0KiB [          ] /lost+found
    8,0KiB [          ] /media
e   4,0KiB [          ] /srv
!   4,0KiB [          ] /root
e   4,0KiB [          ] /mnt
.   0,0  B [          ] /sys
.   0,0  B [          ] /proc
    0,0  B [          ] /dev
[email protected]:/ $ df -h .
Please any help? Thanks
RaTTuS
Contact: Twitter YouTube
Re: fs root at 100%. I can't see why?
Thu Dec 15, 2016 12:07 pm
df -h
have you got stuff stuff mounted under media ?
is this filled before you mount the device
Covfefe
davidtuti
Thu Dec 15, 2016 12:11 pm
RaTTuS wrote:df -h
I dont mount any media
Media is mounted under /
[email protected]:/media $ df -h .
/dev/root         15G    14G  728K 100% /
topguy
Thu Dec 15, 2016 12:12 pm
You have 757 GB of files in /home and cant understand why your SD card i full ?? ;-)
cd /home/pi
du -sh .
du -sh .??*
RaTTuS
Thu Dec 15, 2016 12:15 pm
looks not good
du -h /home/
Covfefe
davidtuti
Thu Dec 15, 2016 12:17 pm
cd /home/pi
du -sh .
du -sh .??*
Sorry I not explain that I have mounted a hard drive external with 2TB under home.
topguy
Thu Dec 15, 2016 12:21 pm
Then your search function will not find the files that are under "/home" on the SD card. unmount the USB-disk and run again.
RaTTuS
Thu Dec 15, 2016 12:23 pm
^ what topguy says
though on a normal raspbian I expect to see more from a
df -h
Covfefe
davidtuti
Thu Dec 15, 2016 12:26 pm
I can see the error.
I had /home/pi/REPO mounted under hard drive. When I dismount these. I see that in these structure exits a folder with 10GB occupied.
So I didn't know that under a montage point I could have files in hard drive and files in sd
RaTTuS
Thu Dec 15, 2016 12:27 pm
yes - if you copy things before it is mounted then after the mount you loose the space and the files on the sd are hidden
Covfefe
