goujam
Re: DTS-MA passthrough
Thu Sep 12, 2013 12:50 pm
boelle wrote:Q: is say raspmbc able to output an DTS-MA as LPMC ?
what excatly happens when i set audio to 7.1 and i play a DTS MA track?
If its dts-ma the pi will output the dts core which will show as dts on you amp
dgorst
Fri Sep 13, 2013 5:09 am
@Dom. Makes sense given how late bitstreaming was introduced I suppose. I'd guess it must be about 7/8ths padding if it's compressed! Irritating ....
FrankHarmann
Fri Sep 13, 2013 1:29 pm
dom wrote:As a consolation, we should be able to get multi channel PCM working (e.g. for multichannel AAC or PCM streams).
I thought multichannel PCM is also using (up to) 192khz 8 channel and only differs in headers bits? So the question is, is the high bandwith the problem (so multichannel PCM will also be limited to f.e. 96khz) or is there some problem in setting the correct headers?
ttringle
Thu Oct 17, 2013 11:24 pm
+1 happy to buy this license
dom
Fri Oct 18, 2013 3:39 pm
FrankHarmann wrote:I thought multichannel PCM is also using (up to) 192khz 8 channel and only differs in headers bits? So the question is, is the high bandwith the problem (so multichannel PCM will also be limited to f.e. 96khz) or is there some problem in setting the correct headers?
Yes, 192kHz 8 channel PCM does not work.
192kHz 4 channel and 96kHz 8 channel both seem to work.
See: https://github.com/raspberrypi/linux/issues/402
suerpkoal
Sun Nov 03, 2013 12:15 am
Even if you would be able to output LPCM streams - the pi wouldn't be able to actively decode dtshd or truehd while playing 1080p video, not to speak of licensing...
suerpkoal
Mon Nov 04, 2013 1:36 pm
BUT you could transcode your mkv files' hd audio tracks on your computer to have multichannel lpcm streams for the pi.
24 bit @ 96 kHz should be more than enough even for the audiophiles ;)
epsi
Thu Dec 05, 2013 8:05 pm
suerpkoal wrote:BUT you could transcode your mkv files' hd audio tracks on your computer to have multichannel lpcm streams for the pi.
How can this be done?
LNGR
Wed Jan 08, 2014 12:55 am
Would most definately pay for this feature.
Fix this devs. Come on!!!!
ramalama
Wed Feb 12, 2014 1:41 pm
It's a shame to see this thread stalled, I really hope the work required gets the OK it's a feature I've been looking for almost a year.
blitzkrieg263
Mon Mar 10, 2014 8:24 am
Do someone know if some progress has been made ??
I'm also ready to pay a few bucks to have DTS-MA passthrough :D
dilopes
Mon Mar 10, 2014 12:23 pm
I think the only way is to get this: http://www.solid-run.com/cubox
Mon Mar 10, 2014 1:37 pm
Dom posted above that it appears this isn't possible. http://www.raspberrypi.org/forum/viewto ... 00#p417424
blitzkrieg263
Tue Mar 18, 2014 11:22 pm
How about the HifiBerry ??
It could be a cheap workaround !! :) It's said that it can Passthrough a 192KHz / 24 bits signal.
http://www.hifiberry.com/hbdigi
ijhammo
Thu Apr 10, 2014 10:45 am
I dont think the hifiberry will work. Toslink cant do DTS-HD
albibox70
Fri Jun 06, 2014 7:20 am
blitzkrieg263 wrote:Do someone know if some progress has been made ??
Hi all,
just installed a raspbmc image on my raspberry box..
simply fantastic media player, more and more reliable compared to xbmc running on pc!
But I agree with you: I'm ready to pay to have DTS-HD MA / DD TrueHD passthrough!
Any update about it?
Regards
Albibox
deleted_user
Tue Jul 15, 2014 4:25 pm
If the hardware support is there, would XBMC software support [1] be enough or is something like a driver missing?
[1] http://wiki.xbmc.org/index.php?title=Au ... assthrough
dom
Wed Jul 16, 2014 8:20 am
deleted_user wrote:If the hardware support is there, would XBMC software support [1] be enough or is something like a driver missing?
The hardware doesn't support it. See http://www.raspberrypi.org/forums/viewt ... 00#p417424
nemo19
Sun Jul 20, 2014 9:35 pm
The current hardware doesn't, but it would be a great feature for a C or B++ version, should there ever be one. I would also happily pay some extra money for this feature, which would make the Pi THE cheapest, most awesome and finally complete media center.
DPIPIMhouse
Thu Jan 08, 2015 7:34 am
Hello all,
I'm new to this forum and recently bought a Pi specifically for RASPBMC. I know a little about audio set ups and I think my understanding of audio pass though is correct.
I posted a problem with my set up under trouble shooting which I though might be a Ground loop problem but I'm now wondering if it is something to do with this topic. Would someone mind taking a look please??
http://www.raspberrypi.org/forums/viewtopic.php?t=95934
Many Thanks
Lee
rickwookie
Mon Feb 02, 2015 9:40 am
So I've got to ask - does the RPi2 change anything regarding HD audio pass-through?
dom
Mon Feb 02, 2015 11:56 pm
rickwookie wrote:So I've got to ask - does the RPi2 change anything regarding HD audio pass-through?
Afraid not. The gpu (which drives hdmi) is unchanged.
Obi-Wan
Wed Feb 04, 2015 1:20 pm
"dom" please tell us you are working on a new Pi C model with HD audio passthrough (eg. DTS-HD) capability, please :-)
goujam
Wed Mar 25, 2015 11:05 am
Well it looks like hd audio can now be decoded to pcm for truehd and dts-ma so the pi can now do HD audio
dom
Wed Mar 25, 2015 12:37 pm
goujam wrote:Well it looks like hd audio can now be decoded to pcm for truehd and dts-ma so the pi can now do HD audio
For more details see kodi thread.
We can now decode lossless 8 channel TrueHD and DTS-HD to PCM, and output 8 channel PCM at 48kHz. You really need a Pi 2 for this.
So for Blu-Rays we can produce lossless HD audio output.
And if you hadn't seen those builds also support playing the 3D MVC stream from Blu-Rays with full HD frame packed display.
