DanDanBu
New release 11-25 video HW acceleration question
Thu Dec 01, 2016 10:03 am
I have a question about the latest release Raspbian on 11-25.
2016-11-25:
* Updates to hardware video acceleration in Chromium browser
My current Raspbian version : 2016-11-25-raspbian-jessie
And I open Chromium to enable hardware acceleration by chrome://flags .
Video Decode is still not support.
decode disable.png (11.93 KiB) Viewed 1710 times
In chrome://gpu
After I enabled, my Chromium become very very slow,
and my cpu almost got 100% while I'm using Chromium.
Is this the right way to open hardware acceleration on Chromium browser?
Or there are other methods to enable it?
Thank you very much.
kusti8
Re: New release 11-25 video HW acceleration question
Thu Dec 01, 2016 12:14 pm
Don't turn that on. It uses software rendering and that's why it's slow. It's enabled out of the box for videos.
DanDanBu
Thu Dec 01, 2016 2:56 pm
kusti8 wrote:Don't turn that on. It uses software rendering and that's why it's slow. It's enabled out of the box for videos.
Thank you for your suggestion :)
May I ask you is there a way to check the follow update in 11-25 version??
Thanks again.
kusti8
Fri Dec 02, 2016 9:51 pm
Thanks again.
What does
apt-cache policy chromium-browser
Say?
DanDanBu
Mon Dec 05, 2016 5:25 am
Thanks again.
What does
Say?
Thank you for your reply.
It says :
chromium-browser:
  Installed: 51.0.2704.91-0ubuntu0.14.04.1.7015
  Candidate: 51.0.2704.91-0ubuntu0.14.04.1.7015
  Version table:
 *** 51.0.2704.91-0ubuntu0.14.04.1.7015 0
        500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
        100 /var/lib/dpkg/status
kusti8
Mon Dec 05, 2016 10:36 pm
That's updated. No need to check anything, any HTML5 video (H264) will work out of the box.
DanDanBu
Tue Dec 06, 2016 1:39 am
Ok!
Thanks a lot!!
jviyer
Fri Dec 09, 2016 12:06 am
I have a rpi3 with jessie. I have chromium-browser installed.
Everything was working fine and then suddenly in the last two days a strange behaviour started happening if I play any *.mp4 file (i.e. I provide a link to the file). The video window starts off right then it keeps shrinking (as if in a special effects) and then boom 5..4..3..2...1 the square/rect window has shrunk to a dot.!
The sound part of the mp4 video file plays correctly.
My packages:
$apt-show-versions  --allversions | grep chromi
[size=85]chromium-browser:armhf 51.0.2704.91-0ubuntu0.14.04.1.7015 install ok installed
chromium-browser:armhf 51.0.2704.91-0ubuntu0.14.04.1.7015 jessie archive.raspberrypi.org
chromium-browser:armhf/jessie 51.0.2704.91-0ubuntu0.14.04.1.7015 uptodate
rpi-chromium-mods:armhf 20161027 install ok installed
rpi-chromium-mods:armhf 20161027 jessie archive.raspberrypi.org
rpi-chromium-mods:armhf/jessie 20161027 uptodate[/size]
Thanks in advance for any pointers to fix this issue.
