XBox One uses HDMI 1.4, which should work fine with the Raspberry Pi. There is probably something wrong with that cable.jcwatchdog wrote:Thanks for the replies. Looking at the hdmi cable that did not work, I think it was from an Xbox one that I had. Maybe this was specific for the Xbox one?
HawaiianPi wrote:XBox One uses HDMI 1.4, which should work fine with the Raspberry Pi. There is probably something wrong with that cable.jcwatchdog wrote:Thanks for the replies. Looking at the hdmi cable that did not work, I think it was from an Xbox one that I had. Maybe this was specific for the Xbox one?
There is no special cable for the Xbox. The 1.4 if it has Ethernet, can end up not working. The Amazon Basics work just fine. I use a DVI to HDMI pigtail with DVI to a monitor I use. The Config.txt was left as is when I made my SD card. You can go to the other side of this site and pull up the information on how to find out HDMI info for your monitor or tv in the config.txt page. If you leave things alone and just make size adjustments in Pixel, it will be just fine. Tweaking in the config.txt is best if you are wanting audio routed through the 3.5mm, having overscan issues.jcwatchdog wrote:That's the thing, the Xbox one works fine with it, just not the raspberry pi
That can happen. The cable might be slightly out of spec in a way that does not affect the XBox One. Maybe the cable is a little noisy, and the XBox One has better noise rejection?jcwatchdog wrote:That's the thing, the Xbox one works fine with it, just not the raspberry pi
Or, put another way, an HDMI device should work with every HDMI cable. If it doesn't, and the cable works with another HDMI device, then there is something wrong with the device that didn't work.HawaiianPi wrote: Bottom line is, an HDMI cable should work with every HDMI device. If it doesn't, and the device works with another HDMI cable, then there is something wrong with the cable that didn't work.
