1080x1200 display
Posted: Mon Nov 28, 2016 2:28 pm
by yunkyoung
I want to use 1080x1200 display module.
I set as below.
/boot/config.txt
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1080 1200 90 0 0 1 1
But after reboot the resolution is 1080x601.
Anyone know how I can set the 1080x1200 resoltion?
Re: 1080x1200 display
Posted: Mon Nov 28, 2016 4:45 pm
by W. H. Heydt
Hmmm... Two things kind of jump out at me...
1. That's an unusual geometry. Could you post a link to the display?
2. By ordering the parameters the way you have, it implies that you are using it in "portrait" mode. Is that your intent?
Posted: Tue Nov 29, 2016 8:34 am
by yunkyoung
Posted: Tue Nov 29, 2016 8:38 am
by yunkyoung
1080x1200 resolution is The spec of display.
Posted: Tue Nov 29, 2016 8:51 am
by lumsdot
maybe they mean if you have two of these vr 3.8 inch displays one for each eye, then the total resolution is 1080 1200.
some sellers are selling them as a pair
Posted: Tue Nov 29, 2016 9:02 am
by RaTTuS
how are you connecting it to the RPI?
Posted: Tue Nov 29, 2016 9:07 am
by yunkyoung
This 1080x1200 module has control board with HDMI interface.
So I can Connect this module with HDMI.
Posted: Tue Nov 29, 2016 9:15 am
by lumsdot
do you have two or just one?
these are meant for vr displays , one for each eye
Posted: Tue Nov 29, 2016 9:16 am
by RaTTuS
remove any dispaly options from the config.txt file and reboot
then what does
tvservice -s
say
Posted: Tue Nov 29, 2016 9:30 am
by lumsdot
oculus rift uses 2 amoled 1200 x 1080 displays,
so looks like your unit should be 1200 x 1080
if they are being sold as a pair with the Hdmi driver for 100 dollars, then this could be another good use for a pi
Posted: Tue Nov 29, 2016 9:51 am
by yunkyoung
After remove display options from the config.txt
tvservice -s say
state 0x4002 [NTSC 4:3], 720x480 @ 60.0Hz, interlaced
Posted: Tue Nov 29, 2016 2:36 pm
by W. H. Heydt
lumsdot wrote:maybe they mean if you have two of these vr 3.8 inch displays one for each eye, then the total resolution is 1080 1200.
The way the data in the link is written, each display would be 1090x1200. That the displays are meant for building your own VR rig explains a lot about why that resolution.
Posted: Tue Nov 29, 2016 2:52 pm
by dom
yunkyoung wrote:tvservice -s say
That is composite output. It suggests the HDMI hotplug signal is not asserted by monitor (it should be). Make sure monitor is powered and connected when you boot.
You can force the hotplug line with hdmi_force_hotplug=1
Posted: Mon May 01, 2017 11:10 pm
by dorian_tl
Hi Yunkyoung,
Were you able to find a solution to getting that screen to work? I also have the same screen and I haven't found a way yet to get the screen to work.
Posted: Tue Aug 22, 2017 12:25 pm
by yuefengli
Hi Yunkyoung,
Hi bro, did you find the way to get that screen to work?I have the same problem now. It can work on my pc, but not raspberry pi 3. Many thanks!
