Campaigner
Lightweight Heatsinks
Tue Nov 15, 2016 4:38 pm
I am working on designing lightweight heatsinks for the PI - has anyone any uses or can they suggest environments where they may be useful?
johnb_summers
Re: Lightweight Heatsinks
Tue Nov 15, 2016 5:20 pm
would seem a job for a 3d printer using metal, to take the heat out of the case, can fill it with channels to so that something else other than air can flow, my son and I are looking at 3D printers at the moment and constructing a friendly case for the Pi 3 CPU could be a worthwhile project as all other cases seem to be constructed more for image than anything else. well the Pi 3 does run a lot hotter than those before it so why should its exterior look the same, isn't that thinking inside the box?
MyPi Developer
http://mypiworld.com/
http://mypi.tech/
https://www.youtube.com/watch?v=US2nyRgg-SY&nohtml5=False
jahboater
Tue Nov 15, 2016 5:22 pm
Campaigner wrote:I am working on designing lightweight heatsinks for the PI - has anyone any uses or can they suggest environments where they may be useful?
The usual aluminium heatsinks for the Pi3 which are a 14-15mm cube, weigh so little that they don't register on my electronic scales - I guess around 1 gram or less. Not sure how much lighter you could go.
I prefer heavier heatsinks to provide some degree of thermal inertia. My C2 has a 70 gram heatsink.
johnb_summers
Tue Nov 15, 2016 5:26 pm
https://www.amazon.co.uk/dp/B01FQHE25U?psc=1
these are great, 100th of a gram, max weight is 200 gram.
MyPi Developer
http://mypi.tech/
jahboater
Tue Nov 15, 2016 6:05 pm
johnb_summers wrote: https://www.amazon.co.uk/dp/B01FQHE25U?psc=1
Thanks, I have ordered them!
Tinderbox (UK)
Tue Nov 15, 2016 7:25 pm
You can get ceramic heatsinks for the Pi, they are supposed to cool better than aluminum or copper.
http://stores.ebay.co.uk/PCArena-Bristo ... ec&submit=
John.
Raspberry Pi 3 Model B
