CFLanger
ALT key stuck in Florence
Sat Nov 05, 2016 1:18 am
I have been developing a portable programmer to flash user parameters into a MODBUS temperature controller that controls a waste gas flare. This device needs touch screen ability with no USB keyboard or mouse. For the most part Florence is working well. But, in order to move windows cut off by the smaller screen height I need the ALT key to move a window to see the OK or CANCEL buttons. When I press the ALT key it gets stuck and never releases. How do I un-stuck it without plugging in a mouse or keyboard?
http://imgur.com/a/8ZjPF
Regards Chris
Senior Programmer
L&J Technologies
CFLanger
Senior Software Engineer at
www.ljtechnologies.com
CFLanger
Re: ALT key stuck in Florence
Sat Nov 05, 2016 1:35 am
C'mon pi guru's, nobody ever answers my posts!!!!!!!!!!!! I really need a solution.
CFLanger
broo0ose
Sat Nov 05, 2016 7:46 am
The version in Debian jessie looks like version 0.6.2-2 whereas the code on Sourceforge is 0.6.3.
Which version are you using ? It might be worth compiling from scratch to see if that fixes it.
I could not see a fix list, the release notes are a bit sparse.
CarlRJ
Sat Nov 05, 2016 2:58 pm
CFLanger wrote:C'mon pi guru's, nobody ever answers my posts!!!!!!!!!!!! I really need a solution.
Seriously? You waited 17 minutes before complaining you hadn't gotten an answer yet? Not everyone here is on at the same time. Not everyone here is even awake at the same time. Give them a chance.
johnb_summers
Sat Nov 05, 2016 3:22 pm
Cant you change the screen size, I have never used these tiny screens so would not know, but I think the first thing I would do is adjust the screen size in the Pi config and if I could not see all the screen would use one that I could, but your signature says you should know how to adjust screen sizes but that's an assumption, my main concern is for Florence, does Zebedee know about this?
MyPi Developer
http://mypiworld.com/
http://mypi.tech/
https://www.youtube.com/watch?v=US2nyRgg-SY&nohtml5=False
wildfire
Sat Nov 05, 2016 3:50 pm
My thoughts exactly, I was going to post before but thought better of it, I can get a little hot headed at times. :)
@OP, perhaps if you were a little less impatiant perhaps more people would respond to your posts.
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
CFLanger
Sat Nov 05, 2016 9:28 pm
Even after pulling in all the dependencies to rebuild Florence to the next revision it still misbehaved. I moved on to using the XVK keyboard. Finally, I didn't expect anyone to post a reply within that short of a time after posting. My comment to myself was basically due to frustration.
CFLanger
RufusVS
Fri Mar 08, 2019 10:26 pm
We are having the same problem.
We are running the Pi in a mini-kiosk mode with Vivaldi browser and Florence keyboard
When we press the Alt-Key on the keyboard it gets stuck on.
With no way to turn it off.
We will lose customer's good faith with that kind of odd behavior
Are there alternative onscreen keyboards? Or should I go with some kind of in-browser keyboard
(if there is such a thing).
lpsw
Sat Mar 09, 2019 12:06 am
It took me 17 seconds to convince myself that I really shouldn't ask the obvious question.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
