kallasur
MySQL database
Wed Oct 19, 2016 11:11 pm
I am trying to store the DHT22 sensor readings in a MySQL database but for some reason it keeps getting stored in the DB as a NULL
how do I resolve this.
If I use dummy values like "33", "22" for the humidity and temp it saves but if I use the humidity or temperature variable then it doesnt save.
below is the code
#!/usr/bin/python
import RPi.GPIO as GPIO
import MySQLdb
import time
import Adafruit_DHT
dht_type = Adafruit_DHT.DHT22
try:
while True:
humidity, temperature = Adafruit_DHT.read_retry(dht_type, 18)
time.sleep(2)
try:
conn = MySQLdb.connect("localhost", "root", "Password1", "db1")
curs = conn.cursor()
curs.execute ("INSERT INTO sensor VALUES (curdate(), curtime(), humidity, temperature)") #this is not working - the date and time is saved in db but the humidity and temp values is a NULL value in the table
////curs.execute ("INSERT INTO sensor VALUES (curdate(), curtime(), 22, 33)") ---- this works but I obviously want to save the humidity and temp values not "33" and "22"
#Not exactly sure whats going on here and why its not working as expected.
conn.commit()
print "Data committed to Database"
except:
print "Error: the database is being rolled back"
conn.rollback()
conn.close()
curs.close()
W. H. Heydt
Re: MySQL database
Thu Oct 20, 2016 3:57 am
Please post the schema for your table.
lmarmisa
Re: MySQL database
Thu Oct 20, 2016 4:09 am
You should not pass python variables to the INSERT command. You should pass the numeric values instead. I recommend this change:
curscommand="INSERT INTO sensor VALUES (curdate(), curtime(), %d, %d)" %(humidity, temperature)
curs.execute (curscommand)
kallasur
Re: MySQL database
Thu Oct 20, 2016 6:15 am
To W. H. Heydt
Create table sensor (date DATE, time TIME, humidity REAL, Temp REAL)
To lmarmisa
Thank you for your help - I really did not know this.
CarlRJ
Re: MySQL database
Thu Oct 20, 2016 6:34 am
Several points:
  • When you post code, especially Python code, where indentation is vital to meaning, always put it in
    [/i] tags. Your code has two try keywords and one except keyword - there's no way to tell, for instance, which try the except a connected to.
  • The immediate problem you're having is because you are only passing the names of your variables in the string that contains the INSERT statement -- how is the code supposed to know that those bits of the string refer to your variables?
  • Despite the suggestion offered above, it's very important that you do not just use string interpolation to stuff the values of your variables directly into the string containing the INSERT statement - this would create a vulnerability in your code for an SQL injection attack. In this particular case, it probably wouldn't be a problem right now, but it's a bad habit to get into. Instead, let the MySQL client take care of putting the values into the query for you - the change might look minor (they both use "%s" in the query), but the effect is significantly different.
  • Along the way, it's best to explicitly name the columns that you're selecting from a table or inserting into a table - this will prevent heartache in the future if you add columns to the table.
  • Also, once a query gets long, it's nice to be able to break it up over several lines.
So, altogether, I think you want something like this (I use generally mysql.connector rather than MySQLdb, but I think this example ought to work for either):
    curs.execute('''INSERT INTO sensor (date, time, humidity, Temp)
                    VALUES (curdate(), curtime(), %s, %s);''',
                 (humidity, temperature,))
kallasur
Re: MySQL database
Thu Oct 20, 2016 8:34 am
I appreciate your reply CarlRJ
I apologize for my inexperience but I'm here to learn and grow
Thank you very much for your help :)
lol - one day I will be on your level *hopefully
Graymalk
Re: MySQL database
Thu Oct 20, 2016 2:52 pm
Just a comment... I don't know if this is "safe" or not but I often (or more like always lol) make everything in my table a varchar and then just cast when I need to. I find MySQL casts on its own which is exceedingly helpful (I find I only have to cast when using something like SQLite). So in the future you may be able to simplify your life by only ever working with strings. Potentially saves on space too because you can restrict the size to fit only your biggest expected number.
mfa298
Re: MySQL database
Thu Oct 20, 2016 4:01 pm
Graymalk wrote:Just a comment... I don't know if this is "safe" or not but I often (or more like always lol) make everything in my table a varchar and then just cast when I need to. I find MySQL casts on its own which is exceedingly helpful (I find I only have to cast when using something like SQLite). So in the future you may be able to simplify your life by only ever working with strings. Potentially saves on space too because you can restrict the size to fit only your biggest expected number.
For pretty much all cases storing a number as a string will take more space than using an appropriate int type. For instance a TINYINT will take 1 byte of space and will store number from -127 to 128 (signed). Storing that same range as a varchar will require 2-5 bytes (a char would always require 4 bytes to store the same value).
Storing everything as a varchar is likely to have a negative impact on indexes as well in the DB as well as potentially hinder doing various operations on data that can be stored as a number (IPv4 IP addresses store nicely as a 4byte integer and let you do some interesting functions to determine all addresses in a network when stored in that way).
CarlRJ
Re: MySQL database
Thu Oct 20, 2016 4:46 pm
kallasur wrote:I apologize for my inexperience but I'm here to learn and grow
Hey, no apologizes. I've learned a lot here too. I'm just trying to help where I can.
Graymalk wrote:Just a comment... I don't know if this is "safe" or not but I often (or more like always lol) make everything in my table a varchar and then just cast when I need to. ... So in the future you may be able to simplify your life by only ever working with strings. ...
On one hand, storing everything as varchars works, on the other, you're failing to take advantage of much of what a database is there to help you do. When you read a string from the database and then convert it to a floating-point number, say, nothing guarantees that the string you read actually represents a valid floating-point number - if it doesn't, how did that invalid value get there? Will the code that converts it fail and crash the program? Will it just silently continue? With what value? How will that affect your computations? Having the database store the field as a floating point number means it cannot ever accidentally end up with something else in it, so when you read it back, you can reasonably expect (vs. just assuming) that you're actually getting a number.
I'd recommend going in the other direction - make full use of the database's capabilities to ensure that only valid data is being stored. This eliminates entire categories of potential errors from your code, and errors that are not possible are errors you won't ever have to spend time tracking down.
In addition, if you store numbers as strings, you won't be able to have queries properly sort the results by those fields (because 10 > 3 but "10" < "3"), you won't be able to select values less than or greater than specific values (for the same reason), you won't be able to have the query add values together, or sum or average a column of numbers, or select the rows with the largest or smallest values. For a lot of potential uses, the database is not only capable of doing such things, but it has code to handle those things which has been extensively tested and debugged already, but you instead are taking the burden of doing those tasks upon yourself. It's a bit like having a car, but getting around by pushing it - you're missing out on its full potential, things it excels at because it was designed to do, and you're doing a lot of hard work yourself instead. ... So you're not simplifying your life, you're actually making it much harder.
Graymalk
Re: MySQL database
Fri Oct 21, 2016 12:04 am
Actually, one huge advantage that strings have is that they *can* store an invalid value. Let's say you're trying to store a record that has a missing value. If the data type is a real, MySQL will automatically turn that into a zero, which has huge consequences because zero is *different*. So if I have an invalid piece of data, I want it to stay that way, not get converted by the engine.
Graymalk
Re: MySQL database
Fri Oct 21, 2016 12:09 am
But I should add that my use case is statistics and machine learning, which may fall a little more closely to the original poster's plans and is why I posted. Someone who is writing software with different aims in mind (especially if there will be human interaction) will be more likely to assume a missing or invalid value is an error rather than something potentially interesting.
CarlRJ
Re: MySQL database
Fri Oct 21, 2016 4:56 am
Graymalk wrote:Actually, one huge advantage that strings have is that they *can* store an invalid value. Let's say you're trying to store a record that has a missing value. If the data type is a real, MySQL will automatically turn that into a zero, which has huge consequences because zero is *different*. So if I have an invalid piece of data, I want it to stay that way, not get converted by the engine.
Ah, but then what you are trying to store are not numbers, but rather "textual data samples that might resemble numbers", in which case varchar is quite reasonable. And I was drawing more from SQL experience in general, and I'd forgotten that MySQL suffers from various forms of brain damage...
In particular, relevant to the current discussion, trying to insert a non-numeric value into a numeric field should always result in an error, not in having the database engine "helping" by substituting in a value like 0. In a proper SQL database, if the server has not been instructed otherwise, the insert statements for rows 4 and 5 (in the example below) should have simply failed*. Rows 2 and 3, by the way, show how to record a missing answer, distinct from 0.
*: (If you tell the database, "go paint the house blue", and it can't find blue paint, it should come back and say, "I can't paint the house blue, because I can't find blue paint" - MySQL seems to think the correct approach is to say, "Okay, the house is painted", and then you go and look and the house is painted yellow, because it could find yellow paint but not blue. That's not following instructions properly. Sigh.)
mysql> CREATE TABLE tests ( foo INT NOT NULL, bar FLOAT, PRIMARY KEY (foo) );
mysql> DESCRIBE tests;
| Field | Type    | Null | Key | Default | Extra |
| foo   | int(11) | NO   | PRI | NULL    |       |
| bar   | float   | YES  |     | NULL    |       |
mysql> INSERT INTO tests (foo, bar) VALUES (1, 5.0);
mysql> INSERT INTO tests (foo, bar) VALUES (2, NULL);
mysql> INSERT INTO tests (foo     ) VALUES (3);
mysql> INSERT INTO tests (foo, bar) VALUES (4, '');
mysql> INSERT INTO tests (foo, bar) VALUES (5, 'hello');
mysql> select * from tests;
| foo | bar  |
|   1 |    5 |
|   2 | NULL |
|   3 | NULL |
|   4 |    0 |
|   5 |    0 |
kallasur
Re: MySQL database
Fri Oct 21, 2016 8:17 am
Thank you to everyone that replied - this really helped
Just a question :-
How do I now draw a graph on an HTML page using these humidity and temp values over time from the MYSQL db.
scotty101
Re: MySQL database
Fri Oct 21, 2016 8:38 am
kallasur wrote: Just a question :-
There are javascript libraries that will allow you to draw charts with minimal effort.
Try something like this http://www.chartjs.org/
kallasur
Re: MySQL database
Fri Oct 21, 2016 8:49 am
Thank you scotty101
Is there a way to do it using HTML - currently most of my webpage is HTML and PHP.
I just want to conform to one standard. but if there is no other option than I will have to use Javascript.
lmarmisa
Re: MySQL database
Fri Oct 21, 2016 9:01 am
If you like PHP, I recommend JpGraph:
http://jpgraph.net/features/gallery.php
Re: MySQL database
Fri Oct 21, 2016 9:06 am
If you really want to stick to HTML generated on the server with PHP then one of the best ways to create simple charts and graphs is to use svg.
For example.
https://css-tricks.com/how-to-make-charts-with-svg/
There are PHP libraries to help generate such graphics:
http://www.goat1000.com/svggraph.php
http://www.pchart.net/
No doubt others around.
Personally I would bite the bullet and do it in Javascript on the page using D3 or plotly.js
https://plot.ly/javascript/
https://d3js.org/
Then you'll find yourself wanting to ditch the old PHP and Apache and do everything in Javascript using node.js as your server.
Re: MySQL database
Fri Oct 21, 2016 9:10 am
If you clone https://github.com/raspberrypi/weather-station-www you'll get some sample code that reads a MySQL database and generates a collection of graphs.
There's even some ready made instructions for how to get it running at: https://www.raspberrypi.org/learning/we ... mo-site.md
This is a doctor free zone.
kallasur
Re: MySQL database
Fri Oct 21, 2016 9:12 am
I will go with the experts advice and try it in Javascript first.
kallasur
Re: MySQL database
Fri Oct 21, 2016 9:13 am
Thank you DougieLawson
I will gave a look :)
Excellent community
Very helpful
afedriansyah
Re: MySQL database
Mon Mar 12, 2018 2:39 am
Hi R-pi
I have created a touch screen buttons consist of "start" "Request material" "Receive material" "Lap" "Emergency" "Finish"
Now i am trying to store integers (as finish products) and lap times when an operator presses the lap button. the result shows in the terminal after i ran the program, but it didn't show in the mysql database. Here is my code can be seen below:
from Tkinter import *
from pymodbus.client.sync import ModbusTcpClient as ModbusClient
import time
import MySQLdb
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(0)
#-------------------------------------------------------GPIO
GPIO.setup(21, GPIO.OUT)#red led
GPIO.setup(20, GPIO.OUT)#yellow led
GPIO.setup(16, GPIO.OUT)#green led
GPIO.output(21, GPIO.HIGH)
GPIO.output(20, GPIO.HIGH)
GPIO.output(16, GPIO.HIGH)
class Screen(Frame):
    def __init__(self, master):
        Frame.__init__(self, master)
#-------------------------------------------------------Main
        self.lbttn_clicks = 0
        self.start_button()
        self.material_button()
        self.receive_button()
        self.emergency_button()
        self.lap_button()
        self.finish_button()
        self.minutes = 0
        self.seconds = 0
#-------------------------------------------------------Modbus Var
        self.LedRed_State = False
        self.LedYellow_State = False
        self.LedGreen_State = False
        self.db = MySQLdb.connect("localhost","root","raspberry","DB_ASSY")
        #self.sql = "INSERT INTO TAB_ASSY (Finished Product, Lap Time) VALUES (%s, %s)"
        self.c= self.db.cursor()
        self.client = ModbusClient('192.168.1.105')
        self.client.connect()
        print "ModbusClient connected..."
        self.time_start = time.time()
        self.pack(fill=BOTH, expand=1)
#-------------------------------------------------------Stopwatch
        self._start = 0.0
        self._elapsedtime = 0.0
        self._running = 0
        self.timestr = StringVar()
        # self.makeWidgets()
#--------------------------------------------------------------------Main funcs
    def start_button(self):
        self.gbttn = Button(self)
        self.gbttn['text'] = "Start"
        self.gbttn['command'] = lambda: [ f() for f in  [self.Start, self.LedGreen, self.LedYellowOff, self.LedRedOff]]
        self.gbttn.place(x = 100, y = 0)
    def material_button(self):
        self.ybttn = Button(self)
        self.ybttn['text'] = "Request Material"
        self.ybttn['command'] = self.LedYellow
        self.ybttn.place(x=100, y=50)
    def receive_button(self):
        self.rbttn = Button(self)
        self.rbttn ['text'] = "Receive Material"
        self.rbttn ['command'] = self.LedYellowOff
        self.rbttn.place(x=100, y=100)
    def emergency_button(self):
        self.ebttn = Button(self)
        self.ebttn['text'] = "Emergency"
        self.ebttn['command'] = lambda: [f() for f in [self.LedRed, self.LedYellowOff, self.LedGreenOff]]
        self.ebttn.place(x=100,y=150)
    def lap_button(self):
        self.lbttn = Button(self)
        self.lbttn['text'] = "Lap"
        self.lbttn['command'] = lambda: [ f() for f in  [self.lap_count, self.Start, self.insert_to_db]]
        self.lbttn.place(x=100,y=200)
    def finish_button(self):
        self.fbttn = Button(self)
        self.fbttn['text'] = "Finish"
        self.fbttn['command'] = lambda: [f() for f in [self.Finish, self.Stop, self.Reset]]
        self.fbttn.place(x=100, y=250)
    def lap_count(self):
        self.lbttn_clicks += 1
        print str(self.lbttn_clicks)
    # def stop_watch(self):
    #     print self.seconds
    #     time.sleep(1)
    #     self.seconds = int(time.time() - self.time_start)
#--------------------------------------------------------------------------------------Main funcs
#--------------------------------------------------------------------------------------Modbus funcs
#--------------------------------------------------------------------------------------Stopwatch funcs
    # def makeWidgets(self):
    #     """ Print the time. """
    #     l = Label(self, textvariable=self.timestr)
    #     self._setTime(self._elapsedtime)
    #     l.pack(fill=X, expand=NO, pady=2, padx=2)
    def _print(self):
        print self._elapsedtime
    def _update(self):
        """ Update the label with elapsed time. """
        self._elapsedtime = time.time() - self._start
        self._timer = self.after(50, self._update)
    def _setTime(self, elap):
        """ Set the time string to Minutes:Seconds:Hundreths """
        minutes = int(elap / 60)
        seconds = int(elap - minutes * 60.0)
        hseconds = int((elap - minutes * 60.0 - seconds) * 100)
        self.timestr.set('%02d:%02d:%02d' % (minutes, seconds, hseconds))
    def Start(self):
        """ Start the stopwatch, ignore if running. """
        if not self._running:
            self._start = time.time() - self._elapsedtime
            self._update()
            self._running = 1
    def insert_to_db(self):
        self.sql = "INSERT INTO TAB_ASSY (Finished Product, Lap Time) where VALUES (%s, %s)"
        try:
            self.execute(sql,( str(self.lbttn_clicks), str(self._elapsedtime)))
            self.db.commit()
        except:
            self.db.rollback()
    def LedGreen(self):
        self.rr = self.client.read_coils(0,6)
        print "Start Button Pressed"
        if self.LedGreen_State == False:
            self.rr.bits[3] = True
            self.rq = self.client.write_coil(3, True)
            self.rq = self.client.write_coil(0, True)
            GPIO.output(16, GPIO.LOW)
            self.LedGreen_State = True
    def LedGreenOff(self):
        print "Green light is off"
        if self.LedGreen_State == True:
            self.rr.bits[3] = False
            self.rq = self.client.write_coil(3, False)
            self.rq = self.client.write_coil(0, False)
    def LedYellow(self):
        print "Request Material"
        if self.LedYellow_State == False:
            self.rr.bits[4] = True
            self.rq = self.client.write_coil(4, True)
            self.rq = self.client.write_coil(1, True)
            GPIO.output(20, GPIO.LOW)
            self.LedYellow_State = True
    def LedYellowOff(self):
        print "Material replenished"
        if self.LedYellow_State == True:
            self.rr.bits[4] = False
            self.rq = self.client.write_coil(4, False)
            self.rq = self.client.write_coil(1, False)
    def LedRed(self):
        print "Assembly process jammed"
        if self.LedRed_State == False:
            self.rr.bits[5] = True
            self.rq = self.client.write_coil(5, True)
            self.rq = self.client.write_coil(2, True)
            GPIO.output(21, GPIO.LOW)
            self.LedRed_State = True
    def LedRedOff(self):
        print "Red light is off"
        if self.LedRed_State == True:
            self.rr.bits[5] = False
            self.rq = self.client.write_coil(5, False)
            self.rq = self.client.write_coil(2, False)
    def Finish(self):
        print "Assembly is finished"
    def Stop(self):
        """ Stop the stopwatch, ignore if stopped. """
        if self._running:
            self.after_cancel(self._timer)
            self._running = 0
            GPIO.cleanup()
    def Reset(self):
        """ Reset the stopwatch. """
    def main():
        while 1:
            insert_to_database()
#----------------------------------------------------------------------------------------------Stopwatch funcs
win = Tk()
win.title("Screen")
win.geometry('800x400')
app = Screen(win)
win.mainloop()
when i ran the script, there was no error but i did not show in the mysql database
I am using raspbian stretch by the way
please share
thank you
bob_binz
Re: MySQL database
Mon Mar 12, 2018 4:48 pm
I think you have an erroneous "where". Try removing it.
BBz
afedriansyah
Re: MySQL database
Tue Mar 13, 2018 1:41 am
I tried it yesterday and it didn't work either. I've tried several things and the results were the same.
I think i should change around this code:
self.sql = "INSERT INTO TAB_ASSY ('Finished_Product',  'Time')  VALUES (%s, %s)"
try:
self.c = self.db.cursor()
self.db.commit()
except:
self.db.rollback()
and
def main():
while 1:
and
if __name__ == '__main__':
     try:
     except:
         print ("No connection to server...")
so when i ran the program the screen button appeared and there were no problems so far and in the terminal it showed, "No connection to server...". Well basically, it means it didn't connect to mysql database and didn't display in phpmyadmin table.
I honestly don't know what I did wrong in the python script and I am kinda stuck for now
I really need help with this
Thank you very much
Re: MySQL database
Tue Mar 13, 2018 2:01 pm
If you're going to post python code in the forum you MUST use [code][/code] tags.
That makes the difference between
And
Python without the left-hand whitespace is undebuggable.
afedriansyah
Re: MySQL database
Wed Mar 14, 2018 1:31 am
I just edited my post now the all the codes should be clear.
But i really still need help with my post above.
Thank you for your time
