foxter
Arduino
Tue Oct 18, 2016 5:27 pm
is there any possibility to install arduino to raspberry pi3? :roll:
mahjongg
Re: Arduino
Tue Oct 18, 2016 5:38 pm
You mean the Arduino sketch environment?
Yes, the Linux version should run...
Gertduino does so, see viewforum.php?f=96 and can program the ATMega chip from the PI.
foxter
Re: Arduino
Tue Oct 18, 2016 5:46 pm
I would like to replace my board with atmega with RP3.
CarlRJ
Re: Arduino
Tue Oct 18, 2016 5:48 pm
You can also connect an Arduino (say, an Uno) to a Pi via USB and talk to the Arduino over the connection using pyserial (or likely in various other ways).
BMS Doug
Re: Arduino
Tue Oct 18, 2016 10:01 pm
Alex Eames has a good set of tutorials for communicating between a Pi and an arduino (the tutorials are written specifically for his arduino compatible board but will be applicable to any arduino or compatible).
Doug.
Re: Arduino
Wed Oct 19, 2016 6:52 pm
foxter wrote:I would like to replace my board with atmega with RP3.
Doing that is non-trivial. The Arduino is a micro-controller that usually runs a single-threaded program that performs a single task. The Raspberry Pi is a full scale general purpose micro-computer running a multi-tasking, multi-threading operating system.
You're comparing apples to oranges.
If you really want to run a Raspberry like an Arduino you have to move away from Linux and get a single task, single threaded program running on the bare metal. That's something that's beyond the skills of 95% of the folks on this forum.
hippy
Re: Arduino
Wed Oct 19, 2016 7:59 pm
Do you mean using your Pi to interface with what your arduino would interface to ?
If so any programming language which allows GPIO access should allow that fairly easily.
If you want to create arduino scripts and run those on a Pi, or have the Pi so it can accept scripts downloaded from an arduino IDE the RasPiArduino project may be what you need -
https://github.com/me-no-dev/RasPiArduino
